date_format
This function is used to convert a date into a string based on the format specified by format.
Syntax
date_format(string date, string format)
Parameters
| Parameter | Mandatory | Type | Description |
| date | Yes | DATE or STRING | Date to be converted The following formats are supported:
| format | Yes | STRING | Format, based on which the date is converted The value is a combination of the time unit (year, month, day, hour, minute, and second) and any character.
Return Values
The return value is of the STRING type.
- If the value of date is not of the DATE or STRING type, the error message "data type mismatch" is displayed.
- If the value of date is of the DATE or STRING type but is not in one of the supported formats, NULL is returned.
- If the value of date is NULL, NULL is returned.
- If the value of format is NULL, NULL is returned.
Example Code
The value 2023-08-14 is returned.
select date_format('2023-08-14','yyyy-MM-dd'); The value 2023-08 is returned.
select date_format('2023-08-14','yyyy-MM') The value 20230814 is returned.
select date_format('2023-08-14','yyyyMMdd') Feedback
