char_matchcount
This parameter is used to return the number of characters in str1 that appear in str2.
Syntax
char_matchcount(string <str1>, string <str2>)
Parameters
| Parameter | Mandatory | Type | Description |
| str1, str2 | Yes | STRING | str1 and str2 to be calculated |
Return Values
The return value is of the BIGINT type.
If the value of str1 or str2 is NULL, NULL is returned.
Example Code
The value 3 is returned.
select char_matchcount('abcz','abcde'); The value NULL is returned.
select char_matchcount(null,'abcde');
