Inserting Data to the DDS Table
Function
This statement is used to insert data in a DLI table to the associated DDS table.
Syntax
- Insert the SELECT query result into a table.
1 2 3 4 5 6 7
INSERT INTO DLI_TABLE SELECT field1,field2... [FROM DLI_TEST] [WHERE where_condition] [LIMIT num] [GROUP BY field] [ORDER BY field] ...;
- Insert a data record into a table.
1 2
INSERT INTO DLI_TABLE VALUES values_row [, values_row ...];
- Overwriting the inserted data
1 2 3 4 5 6 7
INSERT OVERWRITE TABLE DLI_TABLE SELECT field1,field2... [FROM DLI_TEST] [WHERE where_condition] [LIMIT num] [GROUP BY field] [ORDER BY field] ...;
Keywords
For details about the SELECT keywords, see Basic Statements.
Parameters
| Parameter | Description |
| DLI_TABLE | Name of the DLI table for which a datasource connection has been created. |
| DLI_TEST | indicates the table that contains the data to be queried. |
| field1,field2..., field | Column values in the DLI_TEST table must match the column values and types in the DLI_TABLE table. |
| where_condition | Query condition. |
| num | Limit the query result. The num parameter supports only the INT type. |
| values_row | Value to be inserted to a table. Use commas (,) to separate columns. |
Precautions
A DLI table is available.
Example
- Query data in the user table and insert the data into the test table.
1 2 3 4 5 6
INSERT INTO test SELECT ATTR_EXPR FROM user WHERE user_name='cyz' LIMIT 3 GROUP BY user_age
- Insert data 1 into the test table.
INSERT INTO test VALUES (1);
