Updated on 2024-07-04 GMT+08:00
Basic CASE Statement
Function
This statement is used to display result_expression according to the joined results of input_expression and when_expression.
Syntax
CASE input_expression WHEN when_expression THEN result_expression [...n] [ELSE else_result_expression] END;
Keyword
CASE: Subquery is supported in basic CASE statement. However, input_expression and when_expression must be joinable.
Precautions
If there is no input_expression =when_expression with the TRUE value, else_result_expression will be returned when the ELSE clause is specified. If the ELSE clause is not specified, NULL will be returned.
Example
To return the name field and the character that is matched to id from the student table with the following matching rules, run the following statement:
  • If id is 1, 'a' is returned.
  • If id is 2, 'b' is returned.
  • If id is 3, 'c' is returned.
  • Otherwise, NULL is returned.
SELECT name, CASE id WHEN 1 THEN 'a' WHEN 2 THEN 'b' WHEN 3 THEN 'c' ELSE NULL END FROM student;
