Column-Based GROUP BY
Function
This statement is used to group a table based on columns.
Syntax
        1 2  |
        SELECT attr_expr_list FROM table_reference GROUP BY col_name_list;  |
Keywords
Column-based GROUP BY can be categorized into single-column GROUP BY and multi-column GROUP BY.
- Single-column GROUP BY indicates that the GROUP BY clause contains only one column. The fields in col_name_list must exist in attr_expr_list. The aggregate function, count() and sum() for example, is supported in attr_expr_list. The aggregate function can contain other fields.
 - Multi-column GROUP BY indicates that there is more than one column in the GROUP BY clause. The query statement is grouped according to all the fields in the GROUP BY clause. The records with the same fields are put in the same group. Similarly, the fields in the GROUP BY clause must be in the fields in attr_expr_list. The attr_expr_list field can also use the aggregate function.
Precautions
The to-be-grouped table must exist. Otherwise, an error is reported.
Example
Group the student table according to the score and name fields and return the grouping results.
        1 2  |
        SELECT score, count(name) FROM student GROUP BY score,name;  |
