On this page
Show all
Data Permissions List
Updated on 2024-07-04 GMT+08:00
Table 1 describes the SQL statement permission matrix in DLI in terms of permissions on databases, tables, and roles.
Table 1 Permission matrix
Category
SQL statement
Permission
Database
DROP DATABASE db1
The DROP_DATABASE permission of database.db1
CREATE TABLE tb1(...)
The CREATE_TABLE permission of database.db1
CREATE VIEW v1
The CREATE_VIEW permission of database.db1
EXPLAIN query
The EXPLAIN permission of database.db1
Depending on the permissions required by query statements.
Table
SHOW CREATE TABLE tb1
The SHOW_CREATE_TABLE permission of database.db1.tables.tb1
DESCRIBE [EXTENDED|FORMATTED] tb1
The DESCRIBE_TABLE permission of databases.db1.tables.tb1
DROP TABLE [IF EXISTS] tb1
The DROP_TABLE permission of database.db1.tables.tb1
SELECT * FROM tb1
The SELECT permission of database.db1.tables.tb1
SELECT count(*) FROM tb1
SELECT * FROM view1
The SELECT permission of database.db1.tables.view1
SELECT count(*) FROM view1
LOAD DLI TABLE
The INSERT_INTO_TABLE permission of database.db1.tables.tb1
INSERT INTO TABLE
INSERT OVERWRITE TABLE
The INSERT_OVERWRITE_TABLE permission of database.db1.tables.tb1
ALTER TABLE ADD COLUMNS
The ALTER_TABLE_ADD_COLUMNS permission of database.db1.tables.tb1
ALTER TABLE RENAME
The ALTER_TABLE_RENAME permission of database.db1.tables.tb1
ROLE&PRIVILEGE
CREATE ROLE
The CREATE_ROLE permission of db
DROP ROLE
The DROP_ROLE permission of db
SHOW ROLES
The SHOW_ROLES permission of db
GRANT ROLES
The GRANT_ROLE permission of db
REVOKE ROLES
The REVOKE_ROLE permission of db
GRANT PRIVILEGE
The GRANT_PRIVILEGE permission of db or table
REVOKE PRIVILEGE
The REVOKE_PRIVILEGE permission of db or table
SHOW GRANT
The SHOW_GRANT permission of db or table
For privilege granting or revocation on databases and tables, DLI supports the following permissions:
  • Permissions that can be assigned or revoked on databases are as follows:
    • DROP_DATABASE (Deleting a database)
    • CREATE_TABLE (Creating a table)
    • CREATE_VIEW (Creating a view)
    • EXPLAIN (Explaining a SQL statement as an execution plan)
    • CREATE_ROLE (Creating a role)
    • DROP_ROLE (Deleting a role)
    • SHOW_ROLES (Displaying a role)
    • GRANT_ROLE (Bounding a role)
    • REVOKE_ROLE (Unbinding a role)
    • DESCRIBE_TABLE (Describing a table)
    • DROP_TABLE (Deleting a table)
    • Select (Querying a table)
    • INSERT_INTO_TABLE (Inserting)
    • INSERT_OVERWRITE_TABLE (Overwriting)
    • GRANT_PRIVILEGE (Granting permissions to a database)
    • REVOKE_PRIVILEGE (Revoking permissions from a database)
    • SHOW_PRIVILEGES (Checking the database permissions of other users)
    • ALTER_TABLE_ADD_PARTITION (Adding partitions to a partitioned table)
    • ALTER_TABLE_DROP_PARTITION (Deleting partitions from a partitioned table)
    • ALTER_TABLE_RENAME_PARTITION (Renaming table partitions)
    • ALTER_TABLE_RECOVER_PARTITION (Restoring table partitions)
    • ALTER_TABLE_SET_LOCATION (Setting the path of a partition)
    • SHOW_PARTITIONS (Displaying all partitions)
    • SHOW_CREATE_TABLE (Checking table creation statements)
  • Permissions that can be assigned or revoked on tables are as follows:
    • GRANT_PRIVILEGE (Granting permissions to a table)
    • REVOKE_PRIVILEGE (Revoking permissions from a table)
    • SHOW_PRIVILEGES (Checking the table permissions of other users)
    • ALTER_TABLE_ADD_COLUMNS (Adding a column)
    • ALTER_TABLE_RENAME (Renaming a table)
