Creating an OBS Table Using the DataSource Syntax
Function
Create an OBS table using the DataSource syntax.
The main differences between the DataSource and the Hive syntax lie in the supported data formats and the number of supported partitions. For details, see syntax and precautions.
You are advised to use an OBS parallel file system for storage. A parallel file system is a high-performance file system that provides latency in milliseconds, TB/s-level bandwidth, and millions of IOPS. It applies to interactive big data analysis scenarios.
Precautions
- The size of a table is not calculated when the table is created.
- When data is added, the table size will be changed to 0.
- You can check the table size on OBS.
- Table properties cannot be specified using CTAS table creation statements.
- An OBS directory containing subdirectories:
If you specify an OBS directory that contains subdirectories when creating a table, all file types and content within those subdirectories will also be included as table content.
Ensure that all file types in the specified directory and its subdirectories are consistent with the storage format specified in the table creation statement. All file content must be consistent with the fields in the table. Otherwise, errors will be reported in the query.
You can set multiLevelDirEnable to true in the OPTIONS statement to query the content in the subdirectory. The default value is false (Note that this configuration item is a table attribute, exercise caution when performing this operation. Hive tables do not support this configuration item.)
- Instructions on using partitioned tables:
- When a partitioned table is created, the column specified in PARTITIONED BY must be a column in the table, and the partition type must be specified. The partition column supports only the string, boolean, tinyint, smallint, short, int, bigint, long, decimal, float, double, date, and timestamp type.
- When a partitioned table is created, the partition field must be the last one or several fields of the table field, and the sequence of the partition fields must be the same. Otherwise, an error occurs.
- A maximum of 200,000 partitions can be created in a single table.
- Starting from January 2024, new users who register for DLI and use Spark 3.3 or later will be able to use CTAS statements to create partitioned tables when creating tables using the DataSource syntax.
Syntax
1 2 3 4 5 6 7 | CREATE TABLE [IF NOT EXISTS] [db_name.]table_name [(col_name1 col_type1 [COMMENT col_comment1], ...)] USING file_format [OPTIONS (path 'obs_path', key1=val1, key2=val2, ...)] [PARTITIONED BY (col_name1, col_name2, ...)] [COMMENT table_comment] [AS select_statement] |
Keywords
- IF NOT EXISTS: Prevents system errors when the created table exists.
- USING: Storage format.
- OPTIONS: Property name and property value when a table is created.
- COMMENT: Field or table description.
- PARTITIONED BY: Partition field.
- AS: Run the CREATE TABLE AS statement to create a table.
Parameters
| Parameter | Mandatory | Description |
| db_name | No | Database name The value can contain letters, numbers, and underscores (_), but it cannot contain only numbers or start with a number or underscore (_). |
| table_name | Yes | Name of the table to be created in the database The value can contain letters, numbers, and underscores (_), but it cannot contain only numbers or start with a number or underscore (_). The matching rule is ^(?!_)(?![0-9]+$)[A-Za-z0-9_$]*$. Special characters must be enclosed in single quotation marks (''). The table name is case insensitive. |
| col_name | Yes | Column names with data types separated by commas (,) The column name can contain letters, numbers, and underscores (_), but it cannot contain only numbers and must contain at least one letter. The column name is case insensitive. |
| col_type | Yes | Data type of a column field, which is primitive. For details, see Primitive Data Types. |
| col_comment | No | Column field description, which can only be string constants. |
| file_format | Yes | Format of the table to be created, which can be orc, parquet, json, csv, or avro. |
| path | Yes | OBS storage path where data files are stored. You are advised to use an OBS parallel file system for storage. Format: obs://bucketName/tblPath bucketName: bucket name tblPath: directory name. You do not need to specify the file name following the directory. Refer to Table 2 for details about property names and values during table creation. Refer to Table 2 and Table 3 for details about the table property names and values when file_format is set to csv. If there is a folder and a file with the same name in the OBS directory, the path pointed to by the OBS table will prioritize the file over the folder. |
| table_comment | No | Table description, which can only be string constants. |
| select_statement | No | Used in the CREATE TABLE AS statement to insert the SELECT query results of the source table or a data record to a table newly created in the OBS bucket. |
| path | No | Path where the table is stored, which currently can only be an OBS directory |
| multiLevelDirEnable | No | Whether data in subdirectories is iteratively queried when there are nested subdirectories. When this parameter is set to true, all files in the table path, including files in subdirectories, are iteratively read when a table is queried. Default value: false |
| dataDelegated | No | Whether data in the path is cleared when deleting a table or partition Default value: false |
| compression | No | Compression format. This parameter is typically required for Parquet files and is set to zstd. |
| delimiter | No | Data separator Default value: comma (,) |
| quote | No | Quotation character Default value: double quotation marks ("") |
| escape | No | Escape character Default value: backslash (\) |
| multiLine | No | Whether the column data contains carriage return characters or transfer characters. The value true indicates yes and the value false indicates no. Default value: false |
| dateFormat | No | Date format of the date field in a CSV file Default value: yyyy-MM-dd |
| timestampFormat | No | Date format of the timestamp field in a CSV file Default value: yyyy-MM-dd HH:mm:ss |
| mode | No | Mode for parsing CSV files. The options are as follows: Default value: PERMISSIVE
| header | No | Whether the CSV file contains header information. The value true indicates that the table header information is contained, and the value false indicates that the information is not included. Default value: false |
| nullValue | No | Character that represents the null value. For example, nullValue="nl" indicates that nl represents the null value. |
| comment | No | Character that indicates the beginning of the comment. For example, comment= '#' indicates that the line starting with # is a comment. |
| compression | No | Data compression format. Currently, gzip, bzip2, and deflate are supported. If you do not want to compress data, enter none. Default value: none |
| encoding | No | Data encoding format. Available values are utf-8, gb2312, and gbk. Value utf-8 will be used if this parameter is left empty. Default value: utf-8 |
Example 1: Creating an OBS Non-Partitioned Table
Example description: Create an OBS non-partitioned table named table1 and use the USING keyword to set the storage format of the table to orc.
You can store OBS tables in parquet, json, or avro format.
1 2 3 4 5 | CREATE TABLE IF NOT EXISTS table1 ( col_1 STRING, col_2 INT) USING orc OPTIONS (path 'obs://bucketName/filePath'); |
Example 2: Creating an OBS Partitioned Table
Example description: Create a partitioned table named student. The partitioned table is partitioned using facultyNo and classNo. The student table is partitioned by faculty number (facultyNo) and class number (classNo).
In practice, you can select a proper partitioning field and add it to the brackets following the PARTITIONED BY keyword.
1 2 3 4 5 6 7 | CREATE TABLE IF NOT EXISTS student ( Name STRING, facultyNo INT, classNo INT) USING csv OPTIONS (path 'obs://bucketName/filePath') PARTITIONED BY (facultyNo, classNo); |
Example 3: Using CTAS to Create an OBS Non-Partitioned Table Using All or Part of the Data in the Source Table
Example description: Based on the OBS table table1 created in Example 1: Creating an OBS Non-Partitioned Table, use the CTAS syntax to copy data from table1 to table1_ctas.
When using CTAS to create a table, you can ignore the syntax used to create the table being copied. This means that regardless of the syntax used to create table1, you can use the DataSource syntax to create table1_ctas.
In addition, in this example, the storage format of table1 is orc, and the storage format of table1_ctas may be parquet. This means that the storage format of the table created by CTAS may be different from that of the original table.
Use the SELECT statement following the AS keyword to select required data and insert the data to table1_ctas.
The SELECT syntax is as follows: SELECT <Column name > FROM <Table name > WHERE <Related filter criteria>.
- In this example, SELECT * FROM table1 is used. * indicates that all columns are selected from table1 and all data in table1 is inserted into table1_ctas.
1 2 3 4 5 6
CREATE TABLE IF NOT EXISTS table1_ctas USING parquet OPTIONS (path 'obs:// bucketName/filePath') AS SELECT * FROM table1;
- To filter and insert data into table1_ctas in a customized way, you can use the following SELECT statement: SELECT col_1 FROM table1 WHERE col_1 = 'Ann'. This will allow you to select only col_1 from table1 and insert data into table1_ctas where the value equals 'Ann'.
1 2 3 4 5 6 7
CREATE TABLE IF NOT EXISTS table1_ctas USING parquet OPTIONS (path 'obs:// bucketName/filePath') AS SELECT col_1 FROM table1 WHERE col_1 = 'Ann';
Example 4: Creating an OBS Non-Partitioned Table and Customizing the Data Type of a Column Field
Example description: Create an OBS non-partitioned table named table2. You can customize the native data types of column fields based on service requirements.
- STRING, CHAR, or VARCHAR can be used for text characters.
- TIMESTAMP or DATE can be used for time characters.
- INT, SMALLINT/SHORT, BIGINT/LONG, or TINYINT can be used for integer characters.
- FLOAT, DOUBLE, or DECIMAL can be used for decimal calculation.
- BOOLEAN can be used if only logical switches are involved.
For details, see "Data Types" > "Primitive Data Types".
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 | CREATE TABLE IF NOT EXISTS table2 ( col_01 STRING, col_02 CHAR (2), col_03 VARCHAR (32), col_04 TIMESTAMP, col_05 DATE, col_06 INT, col_07 SMALLINT, col_08 BIGINT, col_09 TINYINT, col_10 FLOAT, col_11 DOUBLE, col_12 DECIMAL (10, 3), col_13 BOOLEAN ) USING parquet OPTIONS (path 'obs://bucketName/filePath'); |
Example 5: Creating an OBS Partitioned Table and Customizing OPTIONS Parameters
Example description: When creating an OBS table, you can customize property names and values. For details about OPTIONS parameters, see Table 2.
In this example, an OBS partitioned table named table3 is created and partitioned based on col_2. Configure path, multiLevelDirEnable, dataDelegated, and compression in OPTIONS.
- path: OBS storage path. In this example, the value is obs://bucketName/filePath, where bucketName indicates the bucket name and filePath indicates the actual directory name.
- In big data scenarios, you are advised to use the OBS parallel file system for storage.
- multiLevelDirEnable: In this example, set this parameter to true, indicating that all files and subdirectories in the table path are read iteratively when the table is queried. If this parameter is not required, set it to false or leave it blank (the default value is false).
- dataDelegated: In this example, set this parameter to true, indicating that all data in the path is deleted when a table or partition is deleted. If this parameter is not required, set it to false or leave it blank (the default value is false).
- compression: If the created OBS table needs to be compressed, you can use the keyword compression to configure the compression format. In this example, the zstd compression format is used.
1 2 3 4 5 6 7 8 9 10 11 12 | CREATE TABLE IF NOT EXISTS table3 ( col_1 STRING, col_2 int ) USING parquet PARTITIONED BY (col_2) OPTIONS ( path 'obs://bucketName/filePath', multiLeveldirenable = true, datadelegated = true, compression = 'zstd' ); |
Example 6: Creating an OBS Non-Partitioned Table and Customizing OPTIONS Parameters
Example description: A CSV table is a file format that uses commas to separate data values in plain text. It is commonly used for storing and sharing data, but it is not ideal for complex data types due to its lack of structured data concepts. So, when file_format is set to csv, more OPTIONS parameters can be configured. For details, see Table 3.
In this example, a non-partitioned table named table4 is created with a csv storage format, and additional OPTIONS parameters are used to constrain the data.
- delimiter: data separator, indicating that commas (,) are used as separators between data
- quote: quotation character, indicating that double quotation marks (") are used to quota the reference information in the data
- escape: escape character, indicating that backslashes (\) are used as the escape character for data storage
- multiLine: This parameter is used to set the column data to be stored does not include carriage return or newline characters.
- dataFormat: indicates that the date format of the data field in the CSV file is yyyy-MM-dd.
- timestamoFormat: indicates that the timestamp format in the CSV file is yyyy-MM-dd HH:mm:ss.
- header: indicates that the CSV table contains the table header information.
- nullValue: indicates that null is set to indicate the null value in the CSV table.
- comment: indicates that the CSV table uses a slash (/) to indicate the beginning of a comment.
- compression: indicates that the CSV table is compressed in the gzip, bzip2, or deflate format. If compression is not required, set this parameter to none.
- encoding: indicates that the table uses the utf-8 encoding format. You can choose utf-8, gb2312, or gbk as needed. The default encoding format is utf-8.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | CREATE TABLE IF NOT EXISTS table4 ( col_1 STRING, col_2 INT ) USING csv OPTIONS ( path 'obs://bucketName/filePath', delimiter = ',', quote = '#', escape = '|', multiline = false, dateFormat = 'yyyy-MM-dd', timestampFormat = 'yyyy-MM-dd HH:mm:ss', mode = 'failfast', header = true, nullValue = 'null', comment = '*', compression = 'deflate', encoding = 'utf - 8' ); |
FAQ
- What should I do if the error message "xxx dli datasource v2 tables is only supported in spark3.3 or later version." appears when I create a DataSource table using the default queue?
Ensure that you use Spark 3.3.1 or a later version when creating such a table. If the error message appears, use the Hive syntax to create the table. For details, see Creating an OBS Table Using the Hive Syntax.
- What should I do if the error message "xxx don`t support dli v1 table." appears when I use Spark 3.3.1 to run a Jar job?
This error message indicates that table operations cannot be performed when Spark 3.3.1 is used to execute the Jar job. Use the Hive syntax to recreate the tables' data structure. For example, you can use [STORED AS file_format] CTAS to recreate the table and then run the job. For details, see Creating an OBS Table Using the Hive Syntax.
