Updated on 2026-11-06 GMT+08:00
shiftright
The shiftright function is used to perform a signed right shift, shifting the binary representation of a right by b bits.
Syntax
shiftright(BIGINT a, BIGINT b)
Parameters
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The format of parameter a includes floating-point format, integer format, and string format. If parameter a is not of type BIGINT, it is implicitly converted to BIGINT type before evaluation.
b
Yes
The format of parameter b includes floating-point format, integer format, and string format. If parameter b is not of type BIGINT, it is implicitly converted to BIGINT type before evaluation.
Return Values
Returns a value of type INT.
If a or b is NULL, NULL is returned.
Example Code
Returns 2.
select shiftright(16,3);
Returns 4.
select shiftright(36,3);
Returns 4.
select shiftright(36.123456,3.123456);
Returns NULL.
select shiftright(null,3);
