trunc
The trunc function is used to truncate a date according to a specific format.
Truncation means returning the default value. The default value for year, month, and day is 01. The default value for hour, minute, second, and millisecond is 00.
Syntax
trunc(string date, string format)
Parameters
| Parameter | Mandatory | Type | Description |
| date | Yes | DATE or STRING | The date to be processed. Formats:
| format | Yes | STRING | The target date format for conversion. The format is a combination of time units representing year, month, day, hour, minute, and second, along with any characters.
Return Values
Returns a date value of type DATE, in the format yyyy-mm-dd.
- If date is not of type DATE or STRING, an error is returned with the message "data type mismatch".
- If date is of type DATE or STRING but does not conform to the input format for date values, NULL is returned.
- If the date value is NULL, NULL is returned.
- If the format value is NULL, NULL is returned.
Example Code
Returns 2023-08-01.
select trunc('2023-08-16', 'MM'); Returns 2023-08-01.
select trunc('2023-08-16 10:54:36', 'MM'); Returns NULL.
select trunc(null, 'MM');
