Help Center/ AI DataLake/ Spark reference/ Table Related/ View Table/ Show All Columns of Specified Table
Updated on 2026-11-06 GMT+08:00
Function
View all columns in a specified table. Use FROM/IN to specify the database to which the table belongs.
Syntax
SHOW COLUMNS { FROM | IN } table_name [ { FROM | IN } db_name ]
Parameters
Mandatory
table_name
Yes
Table name.
db_name
No
Database name. Used to qualify the database to which the table belongs.
FROM / IN
Yes (first group)
Specify the table whose columns are to be viewed. FROM and IN have the same function and are interchangeable.
FROM / IN
No (second group)
Specify the database to which the table belongs. Same function as the first group of keywords.
Precautions
  • The specified table must exist in the database. Otherwise, an error will occur.
  • The first group of FROM/IN is followed by the table name. The second group of FROM/IN is followed by the database name. Both have the same function but different positional meanings.
Example 1: View All Columns of a Table
View all columns in the student table.
SHOW COLUMNS FROM student;
Example result:
|col_name |
|id       |
|name     |
|age      |
|score    |
Example 2: View Columns of a Table in a Specified Database
View all columns in the student table in the school_db database.
SHOW COLUMNS FROM student FROM school_db;
Example 3: View Columns of a Table Using the IN Keyword
View all columns in the student table using the IN keyword.
SHOW COLUMNS IN student;
Example 4: Specify a Database Using the IN Keyword
View all columns in the student table in the school_db database using the IN keyword.
SHOW COLUMNS IN student IN school_db;
