Updated on 2026-11-06 GMT+08:00
Alter Database Properties
Function
The ALTER DATABASE statement is used to modify the properties or location of a database. The DATABASE, SCHEMA, and NAMESPACE keywords are interchangeable. If the database does not exist, an error is reported.
Syntax
Set properties
ALTER { DATABASE | SCHEMA | NAMESPACE } database_name
    SET { DBPROPERTIES | PROPERTIES } ( property_name = property_value [, ...] )
Unset properties
    UNSET { DBPROPERTIES | PROPERTIES } ( property_name [, ...] )
Modify location
    SET LOCATION 'new_location'
Keywords
  • DATABASE/SCHEMA/NAMESPACE: All three are equivalent and interchangeable. DATABASE is recommended.
  • SET DBPROPERTIES/SET PROPERTIES: Sets database properties. DBPROPERTIES and PROPERTIES are equivalent.
  • UNSET DBPROPERTIES/UNSET PROPERTIES: Removes database properties. If the specified property does not exist, the command ignores it and executes successfully.
  • SET LOCATION: Modifies the default storage location of the database.
Parameters
Table 1 Parameter descriptions
Mandatory
database_name
Yes
The name of the database to alter.
SET DBPROPERTIES / SET PROPERTIES
Yes
Sets database properties. The specified property value overwrites the existing property value with the same name. Primarily used to record database metadata information.
UNSET DBPROPERTIES / UNSET PROPERTIES
Yes
property_name
Yes
Property name.
property_value
Yes (for SET)
Property value.
SET LOCATION
Yes
Modifies the default storage location of the database. Does not move data from the current database directory to the new location, and does not affect the location of existing tables/partitions under the database.
Precautions
  • Modifying the database location does not automatically migrate existing data. It only affects the default location for newly created tables in the future.
  • The path for SET LOCATION must be in OBS format (e.g., obs://bucket-name/path/).
  • The DATABASE, SCHEMA, and NAMESPACE keywords are interchangeable. DATABASE is recommended.
  • The DBPROPERTIES and PROPERTIES keywords are interchangeable.
  • Use DESCRIBE DATABASE EXTENDED to verify the results of property and location modifications.
Example 1: Set Database Properties
Create database inventory and set properties.
CREATE DATABASE IF NOT EXISTS inventory
  LOCATION 'obs://my-bucket/inventory/';
ALTER DATABASE inventory SET DBPROPERTIES ('Edited-by' = 'John', 'Edit-date' = '01/01/2001');
Verify properties:
DESCRIBE DATABASE EXTENDED inventory;
Example result:
database_description_item
database_description_value
Database Name
inventory
Location
Properties
((Edit-date,01/01/2001), (Edited-by,John))
Example 2: Modify Database Location
ALTER DATABASE inventory SET LOCATION 'obs://my-bucket/new-inventory/';
Verify new location:
Example 3: Remove Database Properties
ALTER DATABASE inventory UNSET DBPROPERTIES ('Edited-by');
Removing a non-existent property is ignored and the command executes successfully:
ALTER DATABASE inventory UNSET DBPROPERTIES ('non-existent');
Example 4: Use SCHEMA/NAMESPACE Keywords
SCHEMA and NAMESPACE are equivalent to DATABASE and can be used interchangeably.
ALTER SCHEMA inventory SET DBPROPERTIES ('Owner' = 'Admin');
ALTER NAMESPACE inventory SET DBPROPERTIES ('Department' = 'Engineering');
