Describe Specific Database
Function
Returns metadata information of a specified database, including the database name, database description, storage path on the file system, etc. If the EXTENDED option is specified, database property information is also returned.
Syntax
1 | DESCRIBE DATABASE [EXTENDED] db_name; |
Keywords
EXTENDED: In addition to displaying the above information, also displays database properties (DBPROPERTIES).
Parameters
| Parameter | Description |
| db_name | Database name. Only letters, digits, and underscores (_) are allowed. It cannot be purely numeric and cannot start with a digit or underscore. |
Precautions
- If the database to be described does not exist, the system reports an error.
- The EXTENDED option additionally displays property information defined in DBPROPERTIES.
- DESC is equivalent to DESCRIBE and can be used interchangeably.
- DATABASE is equivalent to SCHEMA and can be used interchangeably.
Example 1: Describe Basic Database Information
Describe the name, description, and storage path of the employees database.
DESCRIBE DATABASE employees;
Example result:
| database_description_item | database_description_value |
| Database Name | employees |
| Description | For software companies |
| Location | obs://my-bucket/employees/ |
Example 2: Describe Detailed Database Information (Including Properties)
Use the EXTENDED option to view database property information.
DESCRIBE DATABASE EXTENDED employees;
Example result:
| Properties | ((Create-by,kevin), (Create-date,09/01/2019)) |
Example 3: Use DESC Abbreviation
DESC is the abbreviation form of DESCRIBE.
DESC DATABASE employees;
Example 4: Describe a Database Created Using the SCHEMA Keyword
DATABASE is equivalent to SCHEMA.
DESC DATABASE deployment;
Example result:
| Database Name | deployment |
| Description | Deployment environment |
| Location | obs://my-bucket/deployment/ |
