RENAME COLUMN
Enabling Schema Evolution
Set the following parameter:
hoodie.schema.evolution.enable=true
Function
The ALTER TABLE ... RENAME COLUMN command is used to change the column name.
Syntax
ALTER TABLE tableName RENAME COLUMN old_columnName TO new_columnName
Parameter Description
| Parameter | Description |
| tableName | Table name. |
| old_columnName | Old column name. |
| new_columnName | New column name. |
Example
ALTER TABLE table1 RENAME COLUMN a.b.c TO x
a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
After the column name is changed, the change is automatically synchronized to the column comment. The comment is in rename oldName to newName format.
System Response
You can run the SHOW CREATE TABLE command to view the new column name.
