ALTER COLUMN
Updated on 2025-02-22 GMT+08:00
Enabling Schema Evolution
Set the following parameter:
hoodie.schema.evolution.enable=true
Function
The ALTER TABLE ... ALTER COLUMN command is used to change the attributes of a column, such as the column type, position, and comment.
Syntax
ALTER TABLE Table name ALTER
[COLUMN] col_old_name TYPE column_type
[COMMENT] col_comment
[FIRST|AFTER] column_name
Parameter Description
Table 1 ALTER COLUMN parameters
tableName
Table name.
col_old_name
Name of the column to be altered.
column_type
Type of the target column.
col_comment
Column comment.
column_name
New position to place the target column. For example, AFTER column_name indicates that the target column is placed after column_name.
Example
  • Changing the column type
    ALTER TABLE table1 ALTER COLUMN a.b.c TYPE bigint
    a.b.c indicates the full path of a nested column. For details about the nested column rules, see ADD COLUMNS.
    The following changes on column types are supported:
    • int => long/float/double/string/decimal
    • long => float/double/string/decimal
    • float => double/String/decimal
    • From double to string or decimal
    • From decimal to decimal or string
    • From string to date or decimal
    • From date to string
  • Altering other attributes
    ALTER TABLE table1 ALTER COLUMN a.b.c DROP NOT NULL
    ALTER TABLE table1 ALTER COLUMN a.b.c COMMENT 'new comment'
    ALTER TABLE table1 ALTER COLUMN a.b.c FIRST
    ALTER TABLE table1 ALTER COLUMN a.b.c AFTER x
System Response
You can run the DESCRIBE command to view the modified column.
