SHOW_LOG_FILE
Updated on 2025-02-22 GMT+08:00
Function
This command is used to view the meta and record information in log files.
Syntax
  • Viewing meta information:
    call show_logfile_metadata(table => '[table]', log_file_path_pattern => '[log_file_path_pattern]', limit => [limit])
  • Viewing record information:
    call show_logfile_records(table => '[table]', log_file_path_pattern => '[log_file_path_pattern]', merge => '[merge]', limit => [limit])
Parameter Description
Table 1 Parameter descriptions
Mandatory
table
Name of the table to be queried. The value can be in the database.tablename format.
Yes
Path of log files. Regular expression matching is supported.
No
merge
When show_logfile_records is executed, this parameter is used to specify whether to combine records in multiple log files and return them together.
No
limit
Number of returned items
No
Example
call show_logfile_metadata(table => 'hudi_mor', log_file_path_pattern => 'obs://bucket/path/hudi_mor/dt=2021-08-28/.*?log.*?');
call show_logfile_records(table => 'hudi_mor', log_file_path_pattern => 'obs://bucket/path/hudi_mor/dt=2021-08-28/.*?log.*?', merge => false, limit => 1);
Caveats
  • This command is used only for MOR tables.
Permission Requirements
Metadata service provided by DLI
  • SQL permissions:
    database
    table
    None
    SELECT
  • Fine-grained permission: dli:table:select
Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
System Response
You can check if the job status is successful, view the job result, and review the job logs to confirm if there are any exceptions.
