CLUSTERING
Updated on 2025-02-22 GMT+08:00
Function
Performs the clustering operation on Hudi tables. For details, see Hudi Clustering.
Syntax
  • Performing clustering:
    call run_clustering(table=>'[table]', path=>'[path]', predicate=>'[predicate]', order=>'[order]');
  • Viewing the clustering plan:
    call show_clustering(table=>'[table]', path=>'[path]', limit=>[limit]);
Parameter Description
Table 1 Parameter descriptions
Mandatory
table
Name of the table to be queried. The value can be in the database.tablename format.
Either table or path must be set.
path
Path of the table to be queried
predicate
Predicate to be defined, which is used to filter partitions to be clustered
No
order
Sorting field for clustering
No
limit
Number of query results to display
No
Example
call show_clustering(table => 'hudi_table1');
call run_clustering(table => 'hudi_table1', predicate => '(ts >= 1006L and ts < 1008L) or ts >= 1009L', order => 'ts');
call run_clustering(path => 'obs://bucket/path/hudi_test2', predicate => "dt = '2021-08-28'", order => 'id');
Caveats
  • Either table or path must exist. Otherwise, the Hudi table to be clustered cannot be determined.
  • When using the metadata service provided by DLI, this command only supports configuring the table parameter and does not support configuring the path parameter.
  • To cluster a specified partition, refer to the format predicate => "dt = '2021-08-28'".
System Response
You can check if the job status is successful, view the job result, and review the job logs to confirm if there are any exceptions.
