CREATE TABLE AS SELECT
Updated on 2025-02-22 GMT+08:00
Function
This command creates a Hudi table by specifying a list of fields with table attributes. When using the metadata service provided by DLI, only foreign tables can be created, meaning you need to specify the table path through LOCATION.
Syntax
CREATE TABLE [ IF NOT EXISTS] [database_name.]table_name
USING hudi
[ COMMENT table_comment ]
[ LOCATION location_path ]
[ OPTIONS (options_list) ]
[ AS query_statement ]
Parameter Description
Table 1 Parameter descriptions of CREATE TABLE As SELECT
database_name
Name of the database, consisting of letters, numbers, and underscores (_)
table_name
Name of the table in the database, consisting of letters, numbers, and underscores (_)
using
Uses hudi to define and create a Hudi table.
table_comment
Description of the table
location_path
OBS path. If specified, the Hudi table will be created as a foreign table.
options_list
List of Hudi table options.
query_statement
SELECT statement
Example
  • Create a partitioned table.
    create table h2 using hudi
    options (type = 'cow', primaryKey = 'id', preCombineField = 'dt')
    partitioned by (dt)
    as
    select 1 as id, 'a1' as name, 10 as price, 1000 as dt;
  • Create a non-partitioned table.
    create table h3 using hudi
    as
    Load data from a Parquet table to the Hudi table.
    # Create a Parquet table.
    create table parquet_mngd using parquet options(path='obs://bucket/path/parquet_dataset/*.parquet');
    # Create a Hudi table by Creating a Table from Query Results (CTAS).
    create table hudi_tbl using hudi location 'obs://bucket/path/hudi_tbl/' options (
    type = 'cow',
    primaryKey = 'id',
    preCombineField = 'ts'
    partitioned by (datestr) as select * from parquet_mngd;
Caveats
CTAS uses bulk insert to write data for improved loading performance.
Permission Requirements
Metadata service provided by DLI
  • SQL permissions:
    database
    table
    CREATE_TABLE
    Source table: SELECT
  • Fine-grained permissions: dli:table:createTable and dli:table:select
Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
System Response
The table is successfully created. The created Hudi table can be accessed by entering the DLI console, choosing Data Management > Databases and Tables from the left navigation pane, and then clicking the name of the database where the table is created.
