DROP TABLE
Function
This command is used to delete an existing table.
Syntax
DROP TABLE [IF EXISTS] [db_name.]table_name;
Parameter Description
| Parameter | Description |
| db_name | Database name. If this parameter is not specified, the current database is selected. |
| table_name | Name of the table to be deleted. |
Caveats
- In this command, IF EXISTS and db_name are optional.
- When this statement is used to drop a foreign table, the data in the OBS directory is not automatically deleted.
- When deleting an MOR table, the tables with the _rt and _ro suffixes are not automatically deleted. To delete them, you need to execute a DROP statement separately.
Example
DROP TABLE IF EXISTS hudidb.h1;
Permission Requirements
Metadata service provided by DLI
- SQL permissions:
database
table
DROP_TABLE
None
- Fine-grained permission: dli:table:dropTable
Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
System Response
The table will be deleted.
