Help Center/ Data Lake Insight/ Hudi SQL Syntax Reference/ DLI Hudi Development Specifications/ Spark on Hudi Development Specifications/ Parameter Specifications for Spark Asynchronous Task Execution Table Compaction
Updated on 2025-02-22 GMT+08:00
  • Do not manually execute the run schedule command to generate a compaction plan when the writing job has not stopped.
    Incorrect example:
    run schedule on dsrTable
    If there are other tasks writing to this table, executing this operation will result in data loss.
  • When executing the run compaction command, do not set hoodie.run.compact.only.inline to false. Instead, set it to true.
    Incorrect example:
    Set parameters.
    hoodie.run.compact.only.inline=false
    Run the following SQL statement:
    run compaction on dsrTable;
    If there are other tasks writing to this table, executing these operations will result in data loss.
    Correct example: asynchronous compaction
    hoodie.compact.inline = true
    hoodie.run.compact.only.inline=true
