Syntax Compatibility of Common Data Sources
| Syntax | Hive | Hudi |
| show schemas of databases | Y | Y |
| create schema of databases | Y | Y |
| alter schema of databases | Y | N |
| drop schema of databases | Y | Y |
| show tables/show create table/show functions/show session of tables | Y | Y |
| create of tables | Y | N |
| create table TABLENAME as of tables | Y | N |
| insert into TABLENAME values of tables | Y | N |
| insert into TABLENAME select of tables | Y | N |
| insert overwrite TABLENAME values of tables | Y | N |
| insert overwrite TABLENAME select of tables | Y | N |
| alter of tables | Y | N |
| select of tables | Y | Y |
| delete of tables | Y | N |
| drop of tables | Y | N |
| desc/describe TABLENAME of tables | Y | Y |
| comment of tables | Y | N |
| explain of tables | Y | Y |
| show columns of tables | Y | Y |
| select column of tables | Y | Y |
| create view of views | Y | N |
| create or replace view of views | Y | N |
| alter of views | Y | N |
| drop of views | Y | N |
| select of views | Y | Y |
| desc/describe VIEWNAME of views | Y | Y |
| show views/show create view of views | Y | Y |
| show columns of views | Y | Y |
| select column of views | Y | Y |
