On this page
Show all
Help Center/ Data Lake Insight/ HetuEngine SQL Syntax Reference/ Appendix/ Data preparation for the sample table in this document
Updated on 2024-12-31 GMT+08:00
-- Create a table containing TINYINT data:
 CREATE TABLE int_type_t1  (IT_COL1 TINYINT) ;
--Insert data of the TINYINT type.
 insert into int_type_t1  values (TINYINT'10');
-- Create a table containing DECIMAL data:
CREATE TABLE decimal_t1       (dec_col1 DECIMAL(10,3)) ;
– Insert data of the DECIMAL type:
insert into decimal_t1  values (DECIMAL '5.325' );
create table array_tb(col1 array<int>,col2 array<array<int>>);
create table row_tb(col1 row(a int,b varchar));
-- Create a Map table.
create table map_tb(col1 MAP<STRING,INT>);
-- Insert a piece of data of the Map type.
insert into map_tb values(MAP(ARRAY['foo','bar'],ARRAY[1,2]));
--Query data.
select * from map_tb; --   {bar=2, foo=1}
-- Create a ROW table.
create table row_tb (id int,col1 row(a int,b varchar));
-- Insert data of the ROW type.
insert into row_tb values (1,ROW(1,'SSS'));
--Query data.
select * from row_tb; --
 id |     col1
  1 | {a=1, b=SSS}
select col1.b from row_tb; -- SSS
select col1[1] from row_tb; -- 1
-- Creating a STRUCT table.
create table struct_tab (id int,col1 struct<col2: integer, col3: string>);
-- Insert data of the STRUCT type.
 insert into struct_tab VALUES(1, struct<2, 'test'>);
--Query data.
select * from struct_tab; --
 id |        col1
  1 | {col2=2, col3=test}
-- Creating a schema named "web":
CREATE SCHEMA web;
--Create a schema named sales in the Hive data source:
CREATE SCHEMA hive.sales;
-- Creating a schema named traffic, if it does not exist:
CREATE SCHEMA IF NOT EXISTS traffic;
-- Create a new table orders and use the WITH clause to specify the storage format, storage location, and whether the table is a foreign table.
CREATE TABLE orders (
orderkey bigint,
orderstatus varchar,
totalprice double,
orderdate date
WITH (format = 'ORC', location='/user',external=true);
-- If the orders table does not exist, create the orders table and add table comments and column comments:
CREATE TABLE IF NOT EXISTS new_orders (
orderkey bigint,
totalprice double COMMENT 'Price in cents.',
orderdate date
COMMENT 'A table to keep track of orders.';
-- Create the bigger_orders table using the column definition of the orders table:
CREATE TABLE bigger_orders (
another_orderkey bigint,
LIKE orders,
another_orderdate date
CREATE SCHEMA hive.web WITH (location = 'obs://bucket/user');
--Create a partitioned table.
CREATE TABLE hive.web.page_views (
  view_time timestamp,
  user_id bigint,
  page_url varchar,
  ds date,
  country varchar
WITH (
  format = 'ORC',
  partitioned_by = ARRAY['ds', 'country'],
  bucketed_by = ARRAY['user_id'],
  bucket_count = 50
--Insert data.
insert into hive.web.page_views values(timestamp '2020-07-17 23:00:15',bigint '15141','www.local.com',date '2020-07-17','US' );
insert into hive.web.page_views values(timestamp '2020-07-17 23:00:16',bigint '15142','www.abc.com',date '2020-07-17','US' );
insert into hive.web.page_views values(timestamp '2020-07-18 23:00:18',bigint '18148','www.local.com',date '2020-07-18','US' );
-- Delete all data in the partition specified by the WHERE clause from the partitioned table.
delete from hive.web.page_views where ds=date '2020-07-17' and country='US';
--Run the following statement to create the orders_column_aliased table based on the query result of a specified column:
CREATE TABLE orders_column_aliased (order_date, total_price)
AS
SELECT orderdate, totalprice FROM orders;
--Create the orders_by_data table based on the summary result of the orders table.
CREATE TABLE orders_by_date
COMMENT 'Summary of orders by date'
WITH (format = 'ORC')
AS
SELECT orderdate, sum(totalprice) AS price
FROM orders
GROUP BY orderdate;
--If the orders_by_date table does not exist, create the orders_by_date table:
CREATE TABLE IF NOT EXISTS orders_by_date AS
FROM orders
GROUP BY orderdate;
--Create the empty_orders table using the schema that is the same as that of the orders table but does not contain data.
CREATE TABLE empty_orders AS
SELECT *
FROM orders
WITH NO DATA;
--Create a view named test_view in the orders table:
CREATE VIEW test_view (oderkey comment 'orderId',orderstatus comment 'status',half comment 'half') AS
SELECT orderkey, orderstatus, totalprice / 2 AS half FROM orders;
--Create the orders_by_date_view view based on the summary result of the orders table.
CREATE VIEW orders_by_date_view AS
FROM orders
GROUP BY orderdate;
--Create a new view to replace the existing view:
CREATE OR REPLACE VIEW test_view AS
SELECT orderkey, orderstatus, totalprice / 4 AS quarter
FROM orders;
--Modify the definition of an existing table.
--Data preparation.
create table users (id int,name varchar);
--Change the table name from users to people:
ALTER TABLE users RENAME TO people;
--Add the zip column to the people table:
ALTER TABLE people ADD COLUMN zip varchar;
--Delete the zip column from the people table:
ALTER TABLE people DROP COLUMN zip;
--change the column name id in the people table to user_id:
ALTER TABLE people RENAME COLUMN id TO user_id;
create table testfordrop(name varchar);
--CreatE a view.
create view orders_by_date as select * from orders;
--Set the comment information of a table. You can delete the comment by setting the comment information to NULL.
COMMENT ON TABLE people IS 'master table';
--create a table with the column id and name:
CREATE TABLE example AS
SELECT * FROM (
VALUES
(1, 'a'),
(2, 'b'),
(3, 'c')
) AS t (id, name);
--Create the fruit and fruit_copy tables:
create table fruit (name varchar,price double);
create table fruit_copy (name varchar,price double);
--Insert a row of data into the fruit table:
insert into fruit values('LIchee',32);
--Insert multiple lines of data into the fruit table:
insert into fruit values('banana',10),('peach',6),('lemon',12),('apple',7);
--Load the data lines in the fruit table to the fruit_copy table. After the execution, there are five records in the table.
insert into fruit_copy select * from fruit;
--Clear the fruit_copy table, and then load the data in the fruit table to the table. After the execution, there are two records in the fruit_copy table.
insert overwrite fruit_copy select *  from fruit limit 2;
--Create a shipping table:
create table shipping(origin_state varchar(25),origin_zip integer,destination_state varchar(25) ,destination_zip integer,package_weight integer);
--Insert data.
insert into shipping values ('California',94131,'New Jersey',8648,13),
('California',94131,'New Jersey',8540,42),
('California',90210,'Connecticut',6927,1337),
('California',94131,'Colorado',80302,5),
('New York',10002,'New Jersey',8540,3),
('New Jersey',7081,'Connecticut',6708,225);
--Create a table and insert data into the table.
create table cookies_log (cookieid varchar,createtime  date,pv int);
insert into cookies_log values
    ('cookie1',date '2020-07-10',1),
    ('cookie1',date '2020-07-11',5),
    ('cookie1',date '2020-07-12',7),
    ('cookie1',date '2020-07-13',3),
    ('cookie1',date '2020-07-14',2),
    ('cookie1',date '2020-07-15',4),
    ('cookie1',date '2020-07-16',4),
    ('cookie2',date '2020-07-10',2),
    ('cookie2',date '2020-07-11',3),
    ('cookie2',date '2020-07-12',5),
     ('cookie2',date '2020-07-13',6),
      ('cookie2',date '2020-07-14',3),
      ('cookie2',date '2020-07-15',9),
    ('cookie2',date '2020-07-16',7);
--Create a table.
create  table new_shipping (origin_state varchar,origin_zip varchar,packages int ,total_cost int);
--Insert data.
insert into new_shipping
values
('California','94131',25,100),
('California','P332a',5,72),
('California','94025',0,155),
('New Jersey','08544',225,490);
--Create a data table and insert data.
create table salary (dept varchar, userid varchar, sal double);
 insert into salary values ('d1','user1',1000),('d1','user2',2000),('d1','user3',3000),('d2','user4',4000),('d2','user5',5000);
-- Prepare data.
create table cookie_views( cookieid varchar,createtime timestamp,url varchar);
insert into cookie_views values
('cookie1',timestamp '2020-07-10 10:00:02','url20'),
('cookie1',timestamp '2020-07-10 10:00:00','url10'),
('cookie1',timestamp '2020-07-10 10:03:04','urll3'),
('cookie1',timestamp '2020-07-10 10:50:05','url60'),
('cookie1',timestamp '2020-07-10 11:00:00','url70'),
('cookie1',timestamp '2020-07-10 10:10:00','url40'),
('cookie1',timestamp '2020-07-10 10:50:01','url50'),
('cookie2',timestamp '2020-07-10 10:00:02','url23'),
('cookie2',timestamp '2020-07-10 10:00:00','url11'),
('cookie2',timestamp '2020-07-10 10:03:04','url33'),
('cookie2',timestamp '2020-07-10 10:50:05','url66'),
('cookie2',timestamp '2020-07-10 11:00:00','url77'),
('cookie2',timestamp '2020-07-10 10:10:00','url47'),
('cookie2',timestamp '2020-07-10 10:50:01','url55');
CREATE TABLE visit_summaries (  visit_date date,  hll varbinary);
insert into visit_summaries select createtime,cast(approx_set(cookieid) as varbinary) from cookies_log group by createtime;
CREATE TABLE nation (name varchar,  regionkey integer);
insert into nation values ('ETHIOPIA',0),
('MOROCCO',0),
('ETHIOPIA',0),
('KENYA',0),
('ALGERIA',0),
('MOZAMBIQUE',0);
CREATE TABLE region (  name varchar,  regionkey integer);
insert into region values ('ETHIOPIA',0),
('MOROCCO',0),
('ETHIOPIA',0),
('KENYA',0),
('ALGERIA',0),
('MOZAMBIQUE',0);
