Color Function
- bar(x, width)
Description: Renders a single bar in the ANSI bar chart using the default low-frequency red and high-frequency green. For example, if you pass 25% of x and 40 widths to this function. A 10-character red bar followed by 30 spaces will be drawn to create a 40-character bar.
- bar(x, width, low_color, high_color)
Description: Draws a straight line with the specified width in an ANSI bar chart. The x parameter is a double-precision value ranging from 0 to 1. If the value of x is out of the range [0,1], the value is truncated to 0 or 1. low_color and high_color capture the color at either end of the horizontal bar chart. For example, if x is 0.5, width is 80, low_color is 0xFF0000, and high_color is 0x00FF00, this function returns a 40-character bar. The bar consists of red (0xFF0000) and yellow (0xFFFF00), the remaining 80 characters are padded with spaces.
select bar(0.75,80,rgb(255,0,0),rgb(0,255,0));
