On this page
String Functions and Operators
Updated on 2024-12-31 GMT+08:00
String Operators
|| Indicates the character connection.
SELECT 'he'||'llo'; --hello
String Functions
These functions assume that the input string contains valid UTF-8 encoded Unicode code points. They do not explicitly check whether UTF-8 data is valid. For invalid UTF-8 data, the function may return an incorrect result. You can use from_utf8 to correct invalid UTF-8 data.
In addition, these functions operate on Unicode code points, not on characters (or font clusters) visible to users. Some languages combine multiple code points into a single user-perceived character (which is the basic unit of the language writing system), but functions treat each code point as a separate unit.
The lower and upper functions do not perform locale-related, context-related, or one-to-many mappings required by certain languages.
  • chr(n) → varchar
    Description: Returns the value of a character whose Unicode encoding value is n.
    select chr(100); --d
  • char_length(string) → bigint
    For details, see length(string).
  • character_length(string) → bigint
  • codepoint(string) → integer
    Description: Returns the Unicode encoding of a single character.
    select codepoint('d'); --100
  • concat(string1, string2) → varchar
    Description: Concatenates strings.
    select concat('hello','world'); -- helloworld
  • concat_ws(string0, string1, ..., stringN) → varchar
    Description: Concatenates string1, string2, ..., and stringN into a string using string0 as the separator. If string0 is null, the return value is null. If the parameter following the separator is null, the parameter will be skipped during concatenation.
    select concat_ws(',','hello','world'); -- hello,world
    select concat_ws(NULL,'def'); --NULL
    select concat_ws(',','hello',NULL,'world'); -- hello,world
    select concat_ws(',','hello','','world'); -- hello,,world
  • concat_ws(string0, array(varchar)) → varchar
    Description: Concatenates elements in an array using string0 as the separator. If string0 is null, the return value is null. Any null value in the array will be skipped.
    select concat_ws(NULL,ARRAY['abc']);--NULL
    select concat_ws(',',ARRAY['abc',NULL,NULL,'xyz']); -- abc,xyz
    select concat_ws(',',ARRAY['hello','world']); -- hello,world
  • decode(binary bin, string charset) →varchar
    Description: Encodes the first parameter into a string based on the specified character set. The supported character sets include UTF-8, UTF-16BE, UTF-16LE, and UTF-16. If the first parameter is null, null is returned.
    select decode(X'70 61 6e 64 61','UTF-8');
     _col0
     panda
    (1 row)
    select decode(X'00 70 00 61 00 6e 00 64 00 61','UTF-16BE');
     _col0
     panda
    (1 row)
  • encode(string str, string charset) →binary
    Description: Encodes a string based on the specified character set.
    select encode('panda','UTF-8');
         _col0
     70 61 6e 64 61
    (1 row)
  • find_in_set (string str, string strList) →int
    Description: Returns the position of the first occurrence of the string in the comma-separated strList. If a parameter is null, null is returned.
    select find_in_set('ab', 'abc,b,ab,c,def'); -- 3
  • format_number(number x, int d) →string
    Description: Formats the number x to #,###,###.##, reserves d decimal places, and returns the result as a string.
    select format_number(541211.212,2); -- 541,211.21
  • format(format,args...) → varchar
    Description: For details, see Format.
  • locate(string substr, string str, int pos]) →int
    Description: Returns the position of the first occurrence of the substring after the pos position in the string. If the condition is not met, 0 is returned.
    select locate('aaa','bbaaaaa',6);-- 0
    select locate('aaa','bbaaaaa',1);-- 3
    select locate('aaa','bbaaaaa',4);-- 4
  • length(string) → bigint
    Description: Returns the length of the string.
    select length('hello');-- 5
  • levenshtein_distance(string1, string2) → bigint
    Description: Calculates the Levenshtein distance between string1 and string2, that is, the minimum number of single-character edits (insertions, deletions, or substitutions) required to convert string1 to string2.
    select levenshtein_distance('helo word','hello,world'); -- 3
  • hamming_distance(string1, string2) → bigint
    Description: Returns the Hamming distance between character strings 1 and 2, that is, the number of different characters in the corresponding positions. Note that the lengths of the two strings must be the same.
    select hamming_distance('abcde','edcba');-- 4
  • instr(string,substring) → bigint
    Description: Locates the first occurrence of a substring in a string.
    select instr('abcde', 'cd');--3
  • levenshtein(string1, string2) → bigint
    For details, see levenshtein_distance(string1, string2).
    Description: Returns the Levenshtein edit distance between string 1 and string 2, that is, the minimum number of single-character edits (insertion, deletion, or replacement) required to change string 1 to string 2.
    select levenshtein_distance('apple','epplea');-- 2
  • lower(string) → varchar
    Description: Converts characters into lowercase letters.
    select lower('HELLo!');-- hello!
  • lcase(string A) → varchar
    Description: Same as lower(string).
  • ltrim(string) → varchar
    Description: Removes spaces at the beginning of a character string.
    select ltrim('   hello');-- hello
  • lpad(string, size, padstring) → varchar
    Description: Pads the string to the right to resize it using padstring. If size is less than the length of the string, the result is truncated to size characters. The size cannot be negative, and the padding string must not be empty.
    select lpad('myk',5,'fish'); -- domyk
  • luhn_check(string) → boolean
    Description: Tests whether a numeric string is valid based on the Luhn algorithm.
    This checksum function, also known as mod 10, is widely used to validate a variety of identification numbers, such as credit card numbers and ID card numbers.
    select luhn_check('79927398713'); -- true
    select luhn_check('79927398714'); -- false
  • octet_length(string str) → int
    Description: Returns the number of bytes for saving the string encoded using UTF-8.
    select octet_length('query');--5
  • parse_url(string urlString, string partToExtract [, string keyToExtract]) →string
    Description: Returns the specified part of a URL. The valid value of the partToExtract parameter is HOST, PATH, QUERY, REF, PROTOCOL, AUTHORITY, FILE, and USERINFO. keyToExtract is an optional parameter, which is used to select the value corresponding to the key in QUERY.
    select parse_url('https://www.example.com/index.html','HOST');
      _col0
     www.example.com
    (1 row)
    -- Query the value of service in QUERY of the URL.
    select parse_url('https://www.example.com/query/index.html?name=panda','QUERY','name');
     _col0
     panda
    (1 row)
  • position(substring IN string) →bigint
    Description: Returns the position of the first occurrence of a substring in the parent string.
    select position('ab' in 'sssababa');-- 4
  • quote(String text) → string
    Description: Returns a string enclosed in single quotation marks. Strings containing single quotation marks are not supported.
    select quote('DONT');-- 'DONT'
    select quote(NULL);-- NULL
  • repeat2(string str, int n) → string
    Description: Returns a string obtained by repeating the str string for n times.
    select repeat2('abc',4);
        _col0
     abcabcabcabc
    (1 row)
  • replace(string, 'a')→ varchar
    Description: Removes the character a from the character string.
    select replace('hello','e');-- hllo
  • replace(string, 'a', 'b')→ varchar
    Description: Replaces all a characters in a string with b.
    select replace('hello','l','m');-- hemmo
  • reverse(string) → varchar
    Description: reverses the string.
    select reverse('hello');-- olleh
  • rpad(string, size, padstring) → varchar
    select rpad('myk',5,'fish'); -- mykdo
  • rtrim(string) → varchar
    Description: Removes spaces at the end of a character string.
    select rtrim('hello world!   ');-- hello world!
  • space(int n) → varchar
    Description: Returns n spaces.
    select space(4);
     _col0
    (1 row)
    select length(space(4));
     _col0
         4
    (1 row)
  • split(string, delimiter) → array
    Description: Splits the string by delimiters into an array.
    select split('a:b:c:d',':');-- [a, b, c, d]
  • split(string, delimiter, limit) → array
    Description: Splits a string into an array by delimiter. limit indicates the number of elements. The last element contains all the characters of the last string. limit must be a number.
    select split('a:b:c:d',':',2);-- [a, b:c:d]
    select split('a:b:c:d',':',4);-- [a, b, c, d]
  • split_part(string, delimiter, index) → varchar
    Description: Splits a string into an array by delimiter and extracts the elements whose index value is index. The index starts from 1. If the index exceeds the array length, NULL is returned.
    select split_part('a:b:c:d',':',2); -- b
    select split_part('a:b:c:d',':',5); -- NULL
  • split_to_map (string, entryDelimiter, keyValueDelimiter) → map<varchar, varchar>
    Description: Splits a string into mapped key-value pairs by entryDelimiter, and each key-value pair differentiates keys and values by keyValueDelimiter.
    select split_to_map('li:18,wang:17',',',':');--{wang=17, li=18}
  • split_to_multimap(string, entryDelimiter, keyValueDelimiter) -> map(varchar, array(varchar)
    Description: Splits a string by entryDelimiter and keyValueDelimiter and returns a map. Each key corresponds to a value of the array type. entryDelimiter splits a string into key-value pairs, and keyValueDelimiter splits a key-value pair into a key and a value.
    select split_to_multimap('li:18,wang:17,li:19,wang:18',',',':');--{wang=[17, 18], li=[18, 19]}
  • strpos(string, substring) → bigint
    Description: Returns the position of the first occurrence of substring in a string. The value starts from 1. If the value is not found, the value 0 is returned. Example:
    select strpos('hello world!','l'); --3
    select strpos('hello world!','da'); --0
  • str_to_map() For details, see split_to_map().
  • substr(string, start) → varchar
    Description: Truncates a character string from the start position.
    select substr('hello world',3);-- llo world
  • substr(string, start, length) → varchar
    Description: Truncates a character string from the start position. The truncated length is length.
    Generally, it is used to truncate the timestamp format.
    Select substr('2019-03-10 10:00:00',1,10); --Truncate to March 10, 2019.
    Select substr('2019-03-10 10:00:00',1,7); --Truncate to March 2019.
  • substring(string, start) → varchar
    For details, see substr(string, start).
  • substring_index(string A, string delim, int count) → varchar
    Description: If count is a positive number, all content before the count delimiter from the left is returned. If count is a negative number, all content after the count delimiter from the right is returned.
    select substring_index('one.two.three','.',2);
          _col0
     one.two
    (1 row)
    select substring_index('one.two.three','.',-2);
          _col0
     two.three
    (1 row)
    select substring_index('one.two.three','.',0);
     _col0
     NULL
    (1 row)
  • soundex(string A) →varchar
    Description: Returns code (soundex) consisting of four characters to evaluate the similarity of two strings in pronunciation. The rules are as follows:
    Table 1 Character mapping rule
    Character
    Digit
    a, e, h, i, o, u, w, and y
    0
    b. f, p, and v
    c. g, j, k, q, s, x, and z
    2
    d and t
    3
    l
    4
    m and n
    5
    r
    6
    • Extracts the first letter of a string as the first value of soundex.
    • Replaces the latter letters with digits one by one based on the preceding letter mapping rules. If there are consecutive equal numbers, retain only one number and delete.
    • If the result contains more than four digits, the first four digits are used. If the result contains less than four digits, pad 0s to the end.
      select soundex('Miller');
       _col0
       M460
      (1 row)
  • translate(string|char|varchar input, string|char|varchar from, string|char|varchar to) →varchar
    Description: Replaces the string specified by the from parameter with the string specified by the to parameter for an input string. If one of the three parameters is null, NULL is returned.
    select translate('aabbcc','bb','BB');
     _col0
     aaBBcc
    (1 row)
  • trim(string) → varchar
    Description: Removes spaces at the beginning and end of a character string.
    select trim('  hello world!  ');-- hello world!
  • btrim(String str1,String str2) → varchar
    Description: Removes all characters contained in str2 from the beginning and end of str1.
    select btrim('hello','hlo');-- e
  • upper(string) → varchar
    Description: Converts character strings to uppercase letters.
    select upper('heLLo');-- HELLO
  • ucase(string A) → varchar
    Description: Same as upper(string).
  • base64decode(STRING str)
    Description: Performs Base64 reverse encoding on the character string.
    SELECT to_base64(CAST('hello world' as varbinary));-- aGVsbG8gd29ybGQ=
    select base64decode('aGVsbG8gd29ybGQ=');-- hello world
  • jaro_distance(STRING str1, STRING str2)
    Description: Compares the similarity between two character strings.
    select JARO_DISTANCE('hello', 'hell');-- 0.9333333333333332
  • FNV_HASH(type v)
    Description: Calculates the hash value of a character string.
    select FNV_HASH('hello');-- -6615550055289275125
  • word_stem(word) → varchar
    Description: Returns the stem of an English word.
    select word_stem('greating');-- great
  • word_stem(word, lang) → varchar
    Description: Returns the stem of a word in a specified language.
    select word_stem('ultramoderne','fr');-- ultramodern
  • translate(source, from, to) → varchar
    Description: Returns the translated source string by replacing the characters found in the source string with the corresponding characters in the target string. If the from string contains duplicate items, only the first one is used. If the source character does not exist in the from string, the source character is copied without translation. If the index of the matching character in the from string exceeds the length of the to string, the source character is omitted from the result string.
    SELECT translate('abcd', '', ''); -- 'abcd'
    SELECT translate('abcd', 'a', 'z'); -- 'zbcd'
    SELECT translate('abcda', 'a', 'z'); -- 'zbcdz'
    SELECT translate('Palhoça', 'ç','c'); -- 'Palhoca'
    SELECT translate('abcd', 'a', ''); -- 'bcd'
    SELECT translate('abcd', 'a', 'zy'); -- 'zbcd'
    SELECT translate('abcd', 'ac', 'z'); -- 'zbd'
    SELECT translate('abcd', 'aac', 'zq'); -- 'zbd'
Unicode functions
  • normalize(string) → varchar
    Description: Returns a standard string in NFC format.
    select normalize('e');
     _col0
     e
    (1 row)
  • normalize(string, form) → varchar
    Description: Unicode allows you to write the same character in different bytes. For example, é consists of 0xC3 and 0xA9, and consists of 0x65, 0xCC, and 0x81.
    normalize() returns a standard string based on the Unicode standard formats (including NFC, NFD, NFKC, and NFKD) specified by the parameter format. If no parameter format is specified, NFC is used by default.
    select to_utf8('é');
     _col0
     c3 a9
    (1 row)
      _col0
     65 cc 81
    (1 row)
    select normalize('é',NFC)=normalize('é',NFC);
     _col0
     true
    (1 row)
  • to_utf8(string) → varbinary
    Description: Encodes a string into a UTF-8 string.
    select to_utf8('panda');
         _col0
     70 61 6e 64 61
    (1 row)
  • from_utf8(binary) → varchar
    Description: Encodes a binary string into a UTF-8 string. An invalid UTF-8 sequence will be replaced by the Unicode character U+FFFD.
    select from_utf8(X'70 61 6e 64 61');
     _col0
     panda
    (1 row)
  • from_utf8(binary, replace) → varchar
    Description: Encodes a binary string into a UTF-8 string. An invalid UTF-8 sequence will be replaced by the replace parameter. The value of the replace parameter must be a single character or empty to prevent invalid characters from being removed.
    select from_utf8(X'70 61 6e 64 61 b1','!');
     _col0
     panda!
    (1 row)
