Conversion Functions
cast Conversion Function
HetuEngine implicitly converts numeric and character values to the correct type. HetuEngine does not convert between character and numeric types. For example, if a query expects a value of the varchar type, HetuEngine does not automatically convert a value of the bigint type to a value of the varchar type.
Values can be explicitly converted to the specified type, if necessary.
- cast(value AS type) → type
Explicitly converts the type of a value. You can convert a value of the varchar type to the numeric type, or vice versa.
select cast('186' as int ); select cast(186 as varchar);
- try_cast(value AS type) → type
It is similar to cast(). The difference is that null is returned if the conversion fails.
select try_cast(1860 as tinyint); _col0 ------- NULL (1 row)
When a number overflows or a null value is converted, null is returned. However, when the conversion fails, an error is reported.
Example: select try_cast(186 as date);
Cannot cast integer to date
Format
- format(format, args...) → varchar
Description: Formats a string in the format specified by the format string and returns the formatted string.
SELECT format('%s%%',123);-- '123%' SELECT format('%.5f',pi());-- '3.14159' SELECT format('%03d',8);-- '008' SELECT format('%,.2f',1234567.89);-- '1,234,567.89' SELECT format('%-7s,%7s','hello','world');-- 'hello , world' SELECT format('%2$s %3$s %1$s','a','b','c');-- 'b c a' SELECT format('%1$tA, %1$tB %1$te, %1$tY',date'2006-07-04');-- 'Tuesday, July 4, 2006
- format_number(number) → varchar
Description: Returns a string formatted by unit symbol.
SELECT format_number(123456); -- '123K' SELECT format_number(1000000); -- '1M'
Data Size
The parse_presto_data_size function supports the following units:
Unit | Description | Value |
B | Bytes | 1 |
kB | Kilobytes | 1024 |
MB | Megabytes | 10242 |
GB | Gigabytes | 10243 |
TB | Terabytes | 10244 |
PB | Petabytes | 10245 |
EB | Exabytes | 10246 |
ZB | Zettabytes | 10247 |
YB | Yottabytes | 10248 |
parse_presto_data_size(string) → decimal(38)
Convert formatted values with a unit to a number. The value can be a decimal.
SELECT parse_presto_data_size('1B'); -- 1
SELECT parse_presto_data_size('1kB'); -- 1024
SELECT parse_presto_data_size('1MB'); -- 1048576
SELECT parse_presto_data_size('2.3MB'); -- 2411724 Others
typeof(expr) → varchar
Returns the data type name of an expression.
SELECT typeof(123);-- integer
SELECT typeof('cat');-- varchar(3)
SELECT typeof(cos(2)+1.5);-- double Feedback
