On this page
Show all
Lambda Expression
Updated on 2024-12-31 GMT+08:00
The Lambda expression can be represented by ->.
x->x+1
(x,y)->x+y
x->regexp_like(x,'a+')
x->x[1]/x[2]
x->IF(x>0,x,-x)
x->COALESCE(x,0)
x->CAST(xASJSON)
x->x+TRY(1/0)
Most SQL expressions can be used in the Lambda function body except in the following scenarios:
  • Subqueries are not supported.
    x -> 2 + (SELECT 3)
  • Aggregate functions are not supported.
    x -> max(y)
Examples
  • Use the transform() function to obtain the square of array elements.
    SELECT numbers, transform(numbers, n -> n * n) as squared_numbers FROM (VALUES (ARRAY[1, 2]),(ARRAY[3, 4]),(ARRAY[5, 6, 7])) AS t(numbers);
      numbers  | squared_numbers
     [1, 2]    | [1, 4]
     [3, 4]    | [9, 16]
     [5, 6, 7] | [25, 36, 49]
    (3 rows)
  • Use the transform() function to convert array elements into strings. If the conversion fails, the array elements will be converted into NULL to avoid errors.
    SELECT transform(prices, n -> TRY_CAST(n AS VARCHAR) || '$') as price_tags FROM (VALUES (ARRAY[100, 200]),(ARRAY[30, 4])) AS t(prices);
      price_tags
     [100$, 200$]
     [30$, 4$]
    (2 rows)
  • When an operation is performed on an array element, other columns can also be used in the operation. For example, use transform() to calculate the linear equation f(x) =ax + b.
    SELECT xvalues, a, b, transform(xvalues, x -> a * x + b) as linear_function_values FROM (VALUES (ARRAY[1, 2], 10, 5), (ARRAY[3, 4], 4, 2)) AS t(xvalues, a, b);
     xvalues | a  | b | linear_function_values
     [1, 2]  | 10 | 5 | [15, 25]
     [3, 4]  |  4 | 2 | [14, 18]
    (2 rows)
  • Use any_match() to search for an array where at least one element is greater than 100.
    SELECT numbers FROM (VALUES (ARRAY[1,NULL,3]), (ARRAY[10,200,30]), (ARRAY[100,20,300])) AS t(numbers) WHERE any_match(numbers, n ->  COALESCE(n, 0) > 100);
        numbers
     [10, 200, 30]
     [100, 20, 300]
    (2 rows)
  • Use regexp_replace() to capitalize the first letter.
    SELECT regexp_replace('once upon a time ...', '^(\w)(\w*)(\s+.*)$',x -> upper(x[1]) || x[2] || x[3]); -- Once upon a time ...
  • Use the Lambda expression in the aggregate function. For example, use reduce_agg() to calculate the sum of elements by column.
    SELECT reduce_agg(value, 0, (a, b) -> a + b, (a, b) -> a + b) sum_values FROM (VALUES (1), (2), (3), (4), (5)) AS t(value);
     sum_values
             15
    (1 row)
