DESCRIBE
Syntax
DESCRIBE [EXTENDED| FORMATTED] table_name
DESCRIBE [EXTENDED| FORMATTED] table_name PARTITION (partition_spec)
This statement is used to view the metadata information of a specified table. Currently, this syntax can display only the metadata of columns, which is equivalent to the SHOW COLUMNS syntax.
After the EXTENDED keyword is added, all metadata of the table is displayed in the Thrift serialization format.
If the FORMATTED keyword is added, the metadata of the table is displayed in a table.
Example
Display the column information of the fruit data table:
DESCRIBE fruit;
Display the Fruit metadata:
DESCRIBE FORMATTED fruit;
Describe Formatted Table
# col_name data_type comment
name varchar
price integer
# Detailed Table Information
Database: default
Owner: admintest
LastAccessTime: 0
Table Type: MANAGED_TABLE
# Table Parameters:
Owner ggg
STATS_GENERATED_VIA_STATS_TASK workaround for potential lack of HIVE-12730
numFiles 0
numRows 0
orc.compress.size 262144
orc.compression.codec GZIP
orc.row.index.stride 10000
orc.stripe.size 67108864
presto_query_id 20210308_072339_00075_5ck2k@default@HetuEngine
presto_version
rawDataSize 0
totalSize 0
transient_lastDdlTime 1615188219
# Storage Information
SerDe Library: org.apache.hadoop.hive.ql.io.orc.OrcSerde
InputFormat: org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
OutputFormat: org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
Compressed: No
Num Buckets: -1
Bucket Columns: []
Sort Columns: []
serialization.format: 1
(1 row)
Query 20210309_022835_00007_2i9yy@default@HetuEngine, FINISHED, 1 node
Splits: 1 total, 1 done (100.00%)
0:01 [0 rows, 0B] [0 rows/s, 0B/s]; What is your overall rating for this page?
