Help Center/ Data Lake Insight/ HetuEngine SQL Syntax Reference/ HetuEngine SQL Syntax/ DQL Syntax/ Subqueries
Updated on 2024-12-31 GMT+08:00
Subqueries
EXISTS
The EXISTS predicate determines whether to return any row.
SELECT name FROM nation WHERE EXISTS (SELECT * FROM region WHERE region.regionkey = nation.regionkey)
IN
It determines whether any value generated by a subquery is equal to a given expression. The IN result complies with the standard null rule. Only one column must be generated for a subquery.
SELECT name FROM nation WHERE regionkey IN (SELECT regionkey FROM region)
Parent topic: DQL Syntax
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
