Help Center/ Data Lake Insight/ HetuEngine SQL Syntax Reference/ HetuEngine SQL Syntax/ DDL Syntax/ SHOW CREATE TABLE
Updated on 2024-12-31 GMT+08:00
SHOW CREATE TABLE
Syntax
SHOW CREATE TABLE table_name
This statement is used to display the SQL creating statement for a specified data table.
Example
To display the SQL statements that can be used to create the table orders:
CREATE TABLE orders (
orderkey bigint,
orderstatus varchar,
totalprice double,
orderdate date
WITH (format = 'ORC', location='obs://bucket/user',orc_compress='ZLIB',external=true, "auto.purge"=false);
show create table orders;
Create Table
CREATE TABLE hive.default.orders (
orderkey bigint,
totalprice double,
orderdate date
WITH (
external_location = 'obs://bucket/user',
format = 'ORC',
orc_compress = 'ZLIB',
orc_compress_size = 262144,
orc_row_index_stride = 10000,
orc_stripe_size = 67108864
(1 row) Parent topic: DDL Syntax
