CREATE TABLE
Updated on 2024-12-31 GMT+08:00
Syntax
CREATE TABLE [ IF NOT EXISTS ]
[catalog_name.][db_name.]table_name (
{ column_name data_type [ NOT NULL ]
[ COMMENT col_comment]
[ WITH ( property_name = expression [, ...] ) ]
| LIKE existing_table_name
[ { INCLUDING | EXCLUDING } PROPERTIES ]
[ COMMENT table_comment ]
CREATE [EXTERNAL] TABLE [IF NOT EXISTS]
[ COMMENT comment ]
[COMMENT 'table_comment']
[PARTITIONED BY(col_name data_type, ....)]
[CLUSTERED BY (col_name, col_name, ...) [SORTED BY (col_name, col_name, ...)] INTO num_buckets BUCKETS] ]
[ROW FORMAT row_format]
[STORED AS file_format]
[LOCATION 'obs_path']
[TBLPROPERTIES (orc_table_property = value [, ...] ) ]
[ COMMENT comment ]
[SORT BY ([column [, column ...]])]
Remarks
  • During partitioned table creation, if bucket_count is set to -1 and buckets is not set in the table creation statement, the default value 16 is used.
  • By default, external tables are stored in {lakeformation_catalog_url}/{schema_name}.db/{table_name}. {lakeformation_catalog_url} indicates the location configured for the LakeFormation catalog, {schema_name} indicates the schema used for table creation, and {table_name} indicates the table name.
  • Data insertion is not allowed for hosted tables with the external attribute set to true.
Creates a new empty table with specified columns by using CREATE TABLE. Use the CREATE TABLE AS statement to create a table with data.
  • When the optional parameter IF NOT EXISTS is used, no error is reported if the table already exists.
  • The WITH clause can be used to set properties for a newly created table or a single column, such as the storage location of the table and whether the table is an external table.
  • The LIKE clause is used to include all column definitions from an existing table in a new table. You can specify multiple LIKE clauses to allow columns to be copied from multiple tables. If INCLUDING PROPERTIES is specified, all table properties are copied to the new table. If the attribute name specified in the WITH clause is the same as the copied attribute name, the value in the WITH clause is used. By default, the EXCLUDING PROPERTIES attribute is used. You can specify the INCLUDING PROPERTIES attribute for only one table.
  • PARTITIONED BY can be used to specify partition columns. CLUSTERED BY can be used to specify bucket columns. SORT BY and SORTED BY can be used to sort specified bucket columns. BUCKETS can be used to specify the number of buckets. EXTERNAL can be used to create foreign tables. STORED AS can be used to specify the file storage format. LOCATION can be used to specify the storage path on OBS.
Example
  • Create a new table orders and use the WITH clause to specify the storage format, storage location, and whether the table is a foreign table.
    The auto.purge parameter can be used to specify whether to clear related data when data removal operations (such as DROP, DELETE, INSERT OVERWRITE, and TRUNCATE TABLE) are performed.
    • If it is set to true, metadata and data files are cleared.
    • If it is set to false, only metadata is cleared and data files are moved to the OBS recycle bin. The default value is false. You are advised not to change the value. Otherwise, deleted data cannot be restored.
    CREATE TABLE orders (
    orderkey bigint,
    orderstatus varchar,
    totalprice double,
    orderdate date
    WITH (format = 'ORC', location='obs://bucket/user',orc_compress='ZLIB',external=true, "auto.purge"=false);
    -- You can run the DESC FORMATTED statement to view details about table creation.
    desc formatted  orders ;
                               Describe Formatted Table
     # col_name      data_type      comment
     orderkey      bigint
     orderstatus      varchar
     totalprice      double
     orderdate      date
     # Detailed Table Information
     Database:                   default
     Owner:                      admintest
     LastAccessTime:             0
     Table Type:                 EXTERNAL_TABLE
     # Table Parameters:
            EXTERNAL                TRUE
            auto.purge              false
            orc.compress.size       262144
            orc.compression.codec   ZLIB
            orc.row.index.stride    10000
            orc.stripe.size         67108864
            presto_query_id         20220812_084110_00050_srknk@default@HetuEngine
            presto_version          1.2.0-h0.cbu.mrs.320.r1-SNAPSHOT
            transient_lastDdlTime   1660293670
     # Storage Information
     SerDe Library:              org.apache.hadoop.hive.ql.io.orc.OrcSerde
     InputFormat:                org.apache.hadoop.hive.ql.io.orc.OrcInputFormat
     OutputFormat:               org.apache.hadoop.hive.ql.io.orc.OrcOutputFormat
     Compressed:                 No
     Num Buckets:                -1
     Bucket Columns:             []
     Sort Columns:               []
     Storage Desc Params:
            serialization.format    1
    (1 row)
  • Create a table with the specified row format.
    -- When creating a table, use commas (,) to separate fields in each record in the data file.
    CREATE TABLE student(
    id string,birthday string,
    grade int,
    memo string)
    ROW FORMAT DELIMITED FIELDS TERMINATED BY ',';
    -- When creating a table, specify the field delimiter and newline character as '\t' and '\n', respectively.
    CREATE TABLE test(
    id int,
    name string ,
    tel string)
    ROW FORMAT DELIMITED FIELDS TERMINATED BY '\t'
    LINES TERMINATED BY '\n'
    STORED AS TEXTFILE;
  • If the orders table does not exist, create the orders table and add table comments and column comments:
    CREATE TABLE IF NOT EXISTS orders (
    orderkey bigint,
    totalprice double COMMENT 'Price in cents.',
    orderdate date
    COMMENT 'A table to keep track of orders.';
    insert into orders values
    (202011181113,'online',9527,date '2020-11-11'),
    (202011181114,'online',666,date '2020-11-11'),
    (202011181115,'online',443,date '2020-11-11'),
    (202011181115,'offline',2896,date '2020-11-11');
  • Create the bigger_orders table using the column definition of the orders table:
    CREATE TABLE bigger_orders (
    another_orderkey bigint,
    LIKE orders,
    another_orderdate date
    SHOW CREATE TABLE bigger_orders ;
                                Create Table
     CREATE TABLE hive.default.bigger_orders (
        orderkey bigint,
        totalprice double,
        ordersdate date,
     WITH (
        external = false,
        format = 'ORC',
        location = 'obs://bucket/user/hive/warehouse/bigger_orders',
        orc_compress = 'GZIP',
        orc_compress_size = 262144,
        orc_row_index_stride = 10000,
        orc_stripe_size = 67108864
    (1 row)
  • Example of creating a table:
    CREATE EXTERNAL TABLE hetu_test (orderkey bigint, orderstatus varchar, totalprice double, orderdate date) PARTITIONED BY(ds int) SORT BY (orderkey, orderstatus) COMMENT 'test' STORED AS ORC LOCATION '/user' TBLPROPERTIES (orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = 'orderstatus,totalprice');
    CREATE EXTERNAL TABLE hetu_test1 (orderkey bigint, orderstatus varchar, totalprice double, orderdate date) COMMENT 'test' PARTITIONED BY(ds int) CLUSTERED BY (orderkey, orderstatus) SORTED BY (orderkey, orderstatus) INTO 16 BUCKETS STORED AS ORC LOCATION '/user'  TBLPROPERTIES (orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = 'orderstatus,totalprice');
    CREATE TABLE hetu_test2 (orderkey bigint, orderstatus varchar, totalprice double, orderdate date, ds int) COMMENT 'This table is in Hetu syntax' WITH (partitioned_by = ARRAY['ds'], bucketed_by = ARRAY['orderkey', 'orderstatus'], sorted_by = ARRAY['orderkey', 'orderstatus'], bucket_count = 16, orc_compress = 'SNAPPY', orc_compress_size = 6710422, orc_bloom_filter_columns = ARRAY['orderstatus', 'totalprice'], external = true, format = 'orc', location = '/user');
  • Run the following statements to view the table:
    show create table hetu_test1;
                               Create Table
     CREATE TABLE hive.default.hetu_test1 (
        orderkey bigint,
        totalprice double,
        orderdate date,
        ds integer
     COMMENT 'test'
     WITH (
        bucket_count = 16,
        bucketed_by = ARRAY['orderkey','orderstatus'],
        bucketing_version = 1,
        external_location = 'obs://bucket/user',
        format = 'ORC',
        orc_bloom_filter_columns = ARRAY['orderstatus','totalprice'],
        orc_bloom_filter_fpp = 5E-2,
        orc_stripe_size = 67108864,
        sorted_by = ARRAY['orderkey','orderstatus']
    (1 row)
Create a partitioned table.
--Create a schema.
CREATE SCHEMA hive.web WITH (location = 'obs://bucket/user');
--Create a partitioned table.
CREATE TABLE hive.web.page_views (
  view_time timestamp,
  user_id bigint,
  page_url varchar,
  ds date,
  country varchar
WITH (
  format = 'ORC',
  partitioned_by = ARRAY['ds', 'country'],
  bucketed_by = ARRAY['user_id'],
  bucket_count = 50
--View the partition.
SELECT * FROM hive.web."page_views$partitions";
     ds     | country
 2020-07-18 | US
 2020-07-17 | US
--Insert data.
insert into hive.web.page_views values(timestamp '2020-07-17 23:00:15',bigint '15141','www.local.com',date '2020-07-17','US' );
insert into hive.web.page_views values(timestamp '2020-07-18 23:00:15',bigint '18148','www.local.com',date '2020-07-18','US' );
--Query data.
 select * from hive.web.page_views;
        view_time        | user_id |   page_url    |     ds     | country
 2020-07-17 23:00:15.000 |   15141 | www.local.com | 2020-07-17 | US
2020-07-18 23:00:15.000 |   18148 | www.local.com | 2020-07-18 | US
