string_split
The string_split function splits a target string into substrings based on the specified separator and returns a substring list.
string_split(target, separator)
Parameter |
Data Types |
Description |
target |
STRING |
Target string to be processed
separator |
VARCHAR |
Separator. Currently, only single-character separators are supported. |
Example
- Create a Flink OpenSource SQL job by referring to Kafka and Print, enter the following job running script, and submit the job.
When you create a job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
CREATE TABLE kafkaSource ( target STRING, separator VARCHAR ) WITH ( 'connector' = 'kafka', 'topic' = 'KafkaTopic', 'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort', 'properties.group.id' = 'GroupId', 'scan.startup.mode' = 'latest-offset', 'format' = 'json' ); CREATE TABLE printSink ( target STRING, item STRING ) WITH ( 'connector' = 'print' ); insert into printSink select target, item from kafkaSource, lateral table(string_split(target, separator)) as T(item);
- Connect to the Kafka cluster and send the following test data to the Kafka topic:
{"target":"test-flink","separator":"-"} {"target":"flink","separator":"-"} {"target":"one-two-ww-three","separator":"-"}The data is as follows:
Table 2 Test table data target (STRING)
separator (VARCHAR)
test-flink
flink
one-two-ww-three
- View output.
- Method 1:
- Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
- Locate the row that contains the target Flink job, and choose More > FlinkUI in the Operation column.
- On the Flink UI, choose Task Managers, click the task name, and select Stdout to view job logs.
- Method 2: If you select Save Job Log on the Running Parameters tab before submitting the job, perform the following operations:
- Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
- Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
The query result is as follows:+I(test-flink,test) +I(test-flink,flink) +I(flink,flink) +I(one-two-ww-three,one) +I(one-two-ww-three,two) +I(one-two-ww-three,ww) +I(one-two-ww-three,three)
The output data is as follows:
Table 3 Result table data target (STRING)
item (STRING)
test-flink
test
test-flink
flink
flink
flink
one-two-ww-three
one
one-two-ww-three
two
one-two-ww-three
ww
one-two-ww-three
three
- Method 1:
