String Functions
String Functions
DLI offers a wide range of string functions for processing and transforming string data. These functions include concatenation, case conversion, substring extraction, replacement, regex matching, encoding and decoding, format conversion, and more. Additionally, it supports string length calculation, position searching, padding, reversing, and even extracting values from JSON strings using the JSON_VAL function. These features are widely used in data cleansing, text processing, and data analysis scenarios, providing developers with powerful tool support.
For detailed string functions, see Table 1. For more information, see Apache Flink.
SQL Function |
Description |
string1 || string2 |
Returns the concatenation of STRING1 and STRING2. |
CHAR_LENGTH(string) CHARACTER_LENGTH(string) |
Returns the number of characters in a string. |
UPPER(string) |
Returns a string in uppercase. |
LOWER(string) |
Returns a string in lowercase. |
POSITION(string1 IN string2) |
Returns the position (starting from 1) of the first occurrence of STRING1 in STRING2. Returns 0 if STRING1 is not found in STRING2. |
TRIM([ BOTH | LEADING | TRAILING ] string1 FROM string2) |
Returns the result of removing the string that starts/ends/starts and ends with STRING2 from STRING1. By default, both sides' spaces will be removed. |
LTRIM(string) |
Returns the string with left spaces removed from STRING. For example, ' This is a test String.'.ltrim() returns 'This is a test String.'. |
RTRIM(string) |
Returns the string with right spaces removed from STRING. For example, 'This is a test String. '.ltrim() returns 'This is a test String.'. |
REPEAT(string, int) |
Returns a string that is the concatenation of INT number of strings. For example, REPEAT('This is a test String.', 2) returns "This is a test String.This is a test String.". |
REGEXP_REPLACE(string1, string2, string3) |
Returns a string where all substrings in STRING1 that match the regular expression STRING2 are replaced with STRING3. For example, 'foobar'.regexpReplace('oo|ar', '') returns "fb". |
OVERLAY(string1 PLACING string2 FROM integer1 [ FOR integer2 ]) |
Returns a string that replaces INT2 (STRING2's length by default) characters of STRING1 with STRING2 from position INT1. For example, 'xxxxxtest'.overlay('xxxx', 6) returns "xxxxxxxxx", and 'xxxxxtest'.overlay('xxxx', 6, 2) returns "xxxxxxxxxst". |
SUBSTRING(string FROM integer1 [ FOR integer2 ]) |
Returns a substring of STRING starting from position INT1 with length INT2 (default to the end). |
Returns a new string where all occurrences of STRING2 in STRING1 are replaced with STRING3 (non-overlapping). For example, 'hello world'.replace('world', 'flink') returns 'hello flink'; 'ababab'.replace('abab', 'z') returns 'zab'. |
REGEXP_EXTRACT(string1, string2[, integer]) |
Splits the string STRING1 according to the regular expression rule STRING2 and returns the string at the specified position INTEGER1. The regular expression match group index starts at 1, with 0 indicating the entire regular expression match. In addition, the regular expression match group index should not exceed the defined number of groups. For example, REGEXP_EXTRACT('foothebar', 'foo(.*?)(bar)', 2) returns "bar". |
INITCAP(string) |
Returns a new string where the first character of each word is capitalized and the rest are lowercase. Here, a word is defined as a sequence of alphanumeric characters. |
CONCAT(string1, string2, ...) |
Returns a string that concatenates string1, string2, ..., together. If any parameter is NULL, NULL is returned. For example, CONCAT('AA', 'BB', 'CC') returns "AABBCC". |
CONCAT_WS(string1, string2, string3, ...) |
Returns a string that concatenates STRING2, STRING3, ..., together with the separator STRING1. A separator is added between each string to be concatenated. If STRING1 is NULL, NULL is returned. Compared to concat(), concat_ws() automatically skips NULL parameters. For example, concat_ws('~', 'AA', Null(STRING), 'BB', '', 'CC') returns "AA~BB~~CC". |
LPAD(string1, integer, string2) |
Returns a new string where string2 is left-padded to the length of INT. If the length of string1 is less than the value of INT, string1 is returned shortened to an integer character. For example, LPAD('hi', 4, '??') returns "??hi"; LPAD('hi', 1, '??') returns "h". |
RPAD(string1, integer, string2) |
Returns a new string where string2 is right-padded to the length of INT. If the length of string1 is less than the value of INT, returns a new string where string1 is shortened to a length of INT. For example, RPAD('hi', 4, '??') returns "hi??"; RPAD('hi', 1, '??') returns "h". |
FROM_BASE64(string) |
Returns the result of decoding the base64-encoded string1. If the string is NULL, NULL is returned. For example, FROM_BASE64('aGVsbG8gd29ybGQ=') returns "hello world". |
TO_BASE64(string) |
Returns the result of encoding the string to base64. If the string is NULL, NULL is returned. For example, TO_BASE64('hello world') returns "aGVsbG8gd29ybGQ=". |
ASCII(string) |
Returns the numeric value of the first character in the string. If the string is NULL, NULL is returned. For example, ascii('abc') returns 97, and ascii(CAST(NULL AS VARCHAR)) returns NULL. |
CHR(integer) |
Returns the ASCII character that corresponds to the binary value of the integer. If the integer is greater than 255, we first take the modulo of the integer with 255 and return the CHR of the modulo. If the integer is NULL, NULL is returned. For example, chr(97) returns 'a', chr(353) returns 'a', and chr(CAST(NULL AS VARCHAR)) returns NULL. |
DECODE(binary, string) |
Decodes using the provided character set ('US-ASCII', 'ISO-8859-1', 'UTF-8', 'UTF-16BE', 'UTF-16LE', 'UTF-16'). If any of the parameters are empty, the result will also be empty. |
ENCODE(string1, string2) |
Encodes using the provided character set ('US-ASCII', 'ISO-8859-1', 'UTF-8', 'UTF-16BE', 'UTF-16LE', 'UTF-16'). If any of the parameters are empty, the result will also be empty. |
INSTR(string1, string2) |
Returns the position of the first occurrence of string2 in string1. Returns NULL if the value of any parameter is NULL. |
LEFT(string, integer) |
Returns the leftmost substring of the string with a length equal to the integer value. If the integer is negative, an empty string is returned. Returns NULL if the value of any parameter is NULL. |
RIGHT(string, integer) |
Returns the rightmost substring of the string with a length equal to the integer value. If the integer is negative, an empty string is returned. Returns NULL if the value of any parameter is NULL. |
LOCATE(string1, string2[, integer]) |
Returns the position of the first occurrence of string1 after position integer in string2. If not found, returns 0. Returns NULL if either parameter is NULL. |
PARSE_URL(string1, string2[, string3]) |
Returns a specified part from a URL. The valid values for string2 include "HOST", "PATH", "QUERY", "REF", "PROTOCOL", "AUTHORITY", "FILE", and "USERINFO". Returns NULL if the value of any parameter is NULL. For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'HOST') returns 'facebook.com'. You can also extract the value of a specific key in the QUERY by providing a keyword string3 as the third parameter. For example, parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'QUERY', 'k1') returns 'v1'. |
REGEXP(string1, string2) |
Returns TRUE if any (possibly empty) substring of string1 matches the Java regular expression string2, otherwise it returns FALSE. Returns NULL if the value of any parameter is NULL. |
REVERSE(string) |
Returns the reversed string. If the string is NULL, returns NULL. |
SPLIT_INDEX(string1, string2, integer1) |
Splits string1 by the delimiter string2 and returns the integer-th (starting from zero) split string. If the integer is negative, returns NULL. Returns NULL if the value of any parameter is NULL. |
STR_TO_MAP(string1[, string2, string3]) |
Splits string1 into key-value pairs using a separator and returns a map. string2 is the pair separator, and the default separator is a comma (,). string3 is the key-value separator, and the default separator is an equal sign (=). Both separators are regular expressions, so special characters should be escaped beforehand, such as <([{\^-=$!|]})?*+.>. |
SUBSTR(string[, integer1[, integer2]]) |
Returns a substring of a string starting from position integer1 with a length of integer2 (default to the end). |
JSON_VAL(STRING json_string, STRING json_path) |
Returns the value of the specified json_path from the json_string. For details about how to use the functions, see JSON_VAL Function.
The following rules are listed in descending order of priority.
JSON_VAL Function
- Syntax
STRING JSON_VAL(STRING json_string, STRING json_path)
Parameter |
Data Types |
Description |
json_string |
STRING |
JSON object to be parsed |
json_path |
STRING |
Path expression for parsing the JSON string For the supported expressions, see Table 3. |
Expression |
Description |
Root node in the path |
Access array elements |
Array wildcard |
Access child elements |
- Example
- Test input data.
- Use JSON_VAL in SQL statements.
CREATE TABLE kafkaSource ( message string ) WITH ( 'connector' = 'kafka', 'topic-pattern' = '<yourSinkTopic>', 'properties.bootstrap.servers' = '<yourKafkaAddress1>:<yourKafkaPort>,<yourKafkaAddress2>:<yourKafkaPort>', 'properties.group.id' = '<yourGroupId>', 'scan.startup.mode' = 'latest-offset', 'format' = 'csv', 'csv.field-delimiter' = '\u0001', 'csv.quote-character' = '''' ); CREATE TABLE printSink ( message1 STRING, message2 STRING, message3 STRING, message4 STRING, message5 STRING, message6 STRING ) WITH ( 'connector' = 'print' ); insert into printSink select JSON_VAL(message,''), JSON_VAL(message,'$.name'), JSON_VAL(message,'$.grade.science'), JSON_VAL(message,'$.grade.science[*]'), JSON_VAL(message,'$.grade.science[1]'), JSON_VAL(message,'$.grade.dddd') from kafkaSource;
- Check the output of the out file of the taskmanager.
+I[null, James, [80,85], [80,85], 85, null]
