Hive Dimension Table
Updated on 2025-01-10 GMT+08:00
Function
You can use Hive tables as temporal tables and associate them through temporal joins. For more information on temporal joins, refer to temporal join.
Flink supports processing-time temporal joins with Hive tables, which always join the latest version of the temporal table. Flink supports temporary joins with both partitioned and non-partitioned Hive tables. For partitioned tables, Flink automatically tracks the latest partition of the Hive table. For details, see Apache Flink Hive Read & Write.
Caveats
  • Currently, Flink does not support event-time temporal joins with Hive tables.
  • The "Temporal Join The Latest Partition" feature is only supported in Flink STREAMING mode.
  • When you create a Flink OpenSource SQL job, set Flink Version to 1.15 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
  • For details about how to use data types, see Format.
  • Flink 1.15 currently only supports creating OBS tables and DLI lakehouse tables using Hive syntax, which is supported by Hive dialect DDL statements.
    • To create an OBS table using Hive syntax:
      • For the default dialect, set hive.is-external to true in the with properties.
      • For the Hive dialect, use the EXTERNAL keyword in the create table statement.
    • To create a DLI lakehouse table using Hive syntax:
      • For the Hive dialect, add 'is_lakehouse'='true' to the table properties.
  • When creating a Flink OpenSource SQL job, enable checkpointing in the job editing interface.
Syntax Format and Parameter Description
For details, see the syntax format and parameter description in Hive Source Table.
