OBS Source Table
Updated on 2025-01-10 GMT+08:00
Function
The file system connector can be used to read single files or entire directories into a single table.
When using a directory as the source path, there is no defined order of ingestion for the files inside the directory. For more information, see FileSystem SQL Connector.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
CREATE TABLE sink_table (
   name string,
   num INT,
   p_day string,
   p_hour string
) partitioned by (p_day, p_hour) WITH (
   'connector' = 'filesystem',
   'path' = 'obs://*** ',
   'format' = 'parquet',
   'source.monitor-interval'=''
Parameter Description
  • Directory watching
    By default, the file system connector is bounded, that is it will scan the configured path once and then close itself.
    You can enable continuous directory watching by configuring the source.monitor-interval parameter:
    Key
    Default Value
    Data Type
    None
    Duration
    The interval in which the source checks for new files. The interval must be greater than 0.
    Each file is uniquely identified by its path, and will be processed once, as soon as it is discovered.
    The set of files already processed is kept in state during the whole lifecycle of the source, so it's persisted in checkpoints and savepoints together with the source state.
    Shorter intervals mean that files are discovered more quickly, but also imply more frequent listing or directory traversal of the file system/object store.
    If this config option is not set, the provided path will be scanned once, hence the source will be bounded.
  • Available Metadata
    The following connector metadata can be accessed as metadata columns in a table definition. All the metadata are read only.
    Key
    Data Type
    file.path
    STRING NOT NULL
    Full path of the input file
    file.name
    STRING NOT NULL
    Name of the file, that is the farthest element from the root of the filepath
    file.size
    STRING NOT NULL
    Byte count of the file
    file.modification-time
    TIMESTAMP_LTZ(3) NOT NULL
    Modification time of the file
Example
Read data from the OBS table as the data source and output it to the Print connector.
CREATE TABLE obs_source(
   name string,
   num INT,
   `file.path` STRING NOT NULL METADATA
) WITH (
   'path' = 'obs://demo/sink_parquent_obs',
   'source.monitor-interval'='1 h'
CREATE TABLE print (
   name string,
   num INT,
   path  STRING
) WITH (
   'connector' = 'print'
insert into print
select * from obs_source;
Print result:
+I[0e72e, 841255524, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
+I[53524, -2032270969, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
+I[77225, 245599258, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
+I[fc202, -545621464, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
+I[07e9d, 1511139764, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
+I[4e48b, 278014413, /spark.db/sink_parquent_obs/compacted-part-fd4d4cc8-8b18-42d5-b522-9b524500fa23-0-0]
