Updated on 2025-07-04 GMT+08:00
Raw
Function
The Raw format allows to read and write raw (byte based) values as a single column.
  • This format encodes null values as null of byte[] type. This may have limitation when used in upsert-kafka, because upsert-kafka treats null values as a tombstone message (DELETE on the key). Therefore, we recommend avoiding using upsert-kafka connector and the raw format as a value.format if the field can have a null value.
  • The raw format connector is built-in, no additional dependencies are required. For details, see Raw Format.
Supported Connectors
  • Kafka
  • Upsert Kafka
  • FileSystem
Parameter Description
Table 1
Mandatory
Default Value
Type
format
Yes
None
String
Format to be used. Set this parameter to raw.
raw.charset
No
UTF-8
String
Charset to encode the text string.
raw.endianness
No
big-endian
String
Endianness to encode the bytes of numeric value. Options: big-endian and little-endian.
Data Type Mapping
The table below details the SQL types the format supports, including details of the serializer and deserializer class for encoding and decoding.
Table 2 Data type mapping
Flink SQL Type
Value
CHAR/VARCHAR/STRING
A UTF-8 (by default) encoded text string. The encoding charset can be configured by raw.charse.
BINARY / VARBINARY / BYTES
The sequence of bytes itself.
BOOLEAN
A single byte to indicate boolean value, 0 means false, 1 means true.
TINYINT
A single byte of the signed number value.
SMALLINT
Two bytes with big-endian (by default) encoding. The endianness can be configured by raw.endianness.
INT
Four bytes with big-endian (by default) encoding. The endianness can be configured by raw.endianness.
BIGINT
Eight bytes with big-endian (by default) encoding. The endianness can be configured by raw.endianness.
FLOAT
Four bytes with IEEE 754 format and big-endian (by default) encoding. The endianness can be configured by raw.endianness.
DOUBLE
Eight bytes with IEEE 754 format and big-endian (by default) encoding. The endianness can be configured by raw.endianness.
RAW
The sequence of bytes serialized by the underlying TypeSerializer of the RAW type.
Example
Use Kafka to send data and output the data to Print.
  1. Create a datasource connection for the communication with the VPC and subnet where Kafka locates and bind the connection to the queue. Set a security group and inbound rule to allow access of the queue and test the connectivity of the queue using the Kafka IP address. For example, locate a general-purpose queue where the job runs and choose More > Test Address Connectivity in the Operation column. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  2. Create a Flink OpenSource SQL job and select Flink 1.15. Copy the following statement and submit the job:
    CREATE TABLE kafkaSource (
      log string
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'kafkaTopic',
      'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
      'properties.group.id' = 'GroupId',
      'scan.startup.mode' = 'latest-offset',
      'format' = 'raw'
    CREATE TABLE printSink (
      log string
    ) WITH (
      'connector' = 'print'
    insert into printSink select * from kafkaSource;
  3. Insert the following data to the corresponding topic in Kafka:
    47.29.201.179 - - [28/Feb/2019:13:17:10 +0000] "GET /?p=1 HTTP/2.0" 200 5316 "https://domain.com/?p=1" "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36" "2.75"
  4. Perform the following operations to view the data result in the taskmanager.out file:
    1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
    2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
    3. Go to the folder of the date, find the folder whose name contains taskmanager, download the .out file, and view result logs.
    +I[47.29.201.179 - - [28/Feb/2019:13:17:10 +0000] "GET /?p=1 HTTP/2.0" 200 5316 "https://domain.com/?p=1" "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36" "2.75"]
