Parquet
Updated on 2024-04-19 GMT+08:00
Function
The Apache Parquet format allows to read and write Parquet data. For details, see Parquet Format.
Supported Connectors
  • FileSystem
Parameter Description
Table 1 Parameters
Mandatory
Default Value
Data Type
format
Yes
None
String
Specify what format to use, here should be parquet.
parquet.utc-timezone
No
false
Boolean
Use UTC timezone or local timezone to the conversion between epoch time and LocalDateTime. Hive 0.x/1.x/2.x use local timezone. But Hive 3.x use UTC timezone.
Data Type Mapping
Currently, Parquet format type mapping is compatible with Apache Hive, but different with Apache Spark:
  • Timestamp: mapping timestamp type to int96 whatever the precision is.
  • Decimal: mapping decimal type to fixed length byte array according to the precision.
The following table lists the type mapping from Flink type to Parquet type.
Note that currently only writing is supported for composite data types (Array, Map, and Row), while reading is not supported.
Table 2 Data type mapping
Flink SQL Type
Parquet Type
Parquet Logical Type
CHAR/VARCHAR/STRING
BINARY
UTF8
BOOLEAN
BOOLEAN
BINARY/VARBINARY
BINARY
DECIMAL
FIXED_LEN_BYTE_ARRAY
DECIMAL
TINYINT
INT32
INT_8
SMALLINT
INT32
INT_16
INT
INT32
BIGINT
INT64
FLOAT
FLOAT
DOUBLE
DOUBLE
DATE
INT32
DATE
TIME
INT32
TIME_MILLIS
TIMESTAMP
INT96
ARRAY
LIST
MAP
MAP
ROW
STRUCT
Example
Use Kafka to send data and output the data to Print.
  1. Create a datasource connection for the communication with the VPC and subnet where Kafka locates and bind the connection to the queue. Set a security group and inbound rule to allow access of the queue and test the connectivity of the queue using the Kafka IP address. For example, locate a general-purpose queue where the job runs and choose More > Test Address Connectivity in the Operation column. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  2. Create a Flink OpenSource SQL job and enable checkpointing. Copy the following statement and submit the job:
    CREATE TABLE kafkaSource (
      order_id string,
      order_channel string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'connector' = 'kafka',
      'topic-pattern' = 'kafkaTopic',
      'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
      'properties.group.id' = 'GroupId',
      'scan.startup.mode' = 'latest-offset',
      'format' = 'json'
    CREATE TABLE sink (
      order_id string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'connector' = 'filesystem',
      'format' = 'parquet',
      'path' = 'obs://xx'
    insert into sink select * from kafkaSource;
  3. Insert the following data into the source Kafka topic:
    202103251505050001,appShop,2021-03-25 15:05:05,500.00,400.00,2021-03-25 15:10:00,0003,Cindy,330108
    202103241606060001,appShop,2021-03-24 16:06:06,200.00,180.00,2021-03-24 16:10:06,0001,Alice,330106
  4. Read the Parquet file in the OBS path configured in the sink table. The data results are as follows:
    202103251202020001, miniAppShop, 2021-03-25 12:02:02, 60.0, 60.0, 2021-03-25 12:03:00, 0002, Bob, 330110
    202103241606060001, appShop, 2021-03-24 16:06:06, 200.0, 180.0, 2021-03-24 16:10:06, 0001, Alice, 330106
