Updated on 2025-01-10 GMT+08:00
CSV
Function
The CSV format allows you to read and write CSV data based on a CSV schema. Currently, the CSV schema is derived from table schema. For details, see CSV Format.
Supported Connectors
  • Kafka
  • Upsert Kafka
  • FileSystem
Parameters
Table 1 Description
Mandatory
Default value
Type
format
Yes
None
String
Format to be used. Set the value to csv.
csv.field-delimiter
No
String
Field delimiter character, which must be a single character. You can use backslash to specify special characters, for example, \t represents the tab character. You can also use unicode to specify them in plain SQL, for example, 'csv.field-delimiter' = U&'\0001' represents the 0x01 character.
csv.disable-quote-character
No
false
Boolean
Disabled quote character for enclosing field values. If you set this parameter to true, csv.quote-character cannot be set.
csv.quote-character
No
String
Quote character for enclosing field values.
csv.allow-comments
No
false
Boolean
Ignore comment lines that start with #. If you set this parameter to true, make sure to also ignore parse errors to allow empty rows.
csv.ignore-parse-errors
No
false
Boolean
Whether fields and rows with parse errors will be skipped or failed. The default value is false, indicating that an error will be thrown. Fields are set to null in case of errors.
csv.array-element-delimiter
No
String
Array element delimiter string for separating array and row element values.
csv.escape-character
No
None
String
Escape character for escaping values
csv.null-literal
No
None
String
Null literal string that is interpreted as a null value.
Data Type Mapping
Currently, the CSV schema is always derived from table schema. Explicitly defining a CSV schema is not supported yet. Flink CSV format uses jackson databind API to parse and generate CSV string.
Table 2 Data type mapping
Flink SQL Type
CSV Type
CHAR/VARCHAR/STRING
String
BOOLEAN
Boolean
BINARY/VARBINARY
string with encoding: base64
DECIMAL
Number
TINYINT
Number
SMALLINT
Number
INT
Number
BIGINT
Number
FLOAT
Number
DOUBLE
Number
DATE
string with format: date
TIME
string with format: time
TIMESTAMP
string with format: date-time
INTERVAL
Number
ARRAY
array
ROW
object
Example
Use Kafka to send data and output the data to Print.
  1. Create a datasource connection for the communication with the VPC and subnet where Kafka locates and bind the connection to the queue. Set a security group and inbound rule to allow access of the queue and test the connectivity of the queue using the Kafka IP address. For example, locate a general-purpose queue where the job runs and choose More > Test Address Connectivity in the Operation column. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  2. Create a Flink OpenSource SQL job. Copy the following statement and submit the job:
    CREATE TABLE kafkaSource (
      order_id string,
      order_channel string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'kafkaTopic',
      'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
      'properties.group.id' = 'GroupId',
      'scan.startup.mode' = 'latest-offset',
      'format' = 'csv'
    CREATE TABLE printSink (
      order_id string,
      order_time string,
      pay_amount double,
      real_pay double,
      pay_time string,
      user_id string,
      user_name string,
      area_id string
    ) WITH (
      'connector' = 'print'
    insert into printSink select * from kafkaSource;
  3. Insert the following data into the source Kafka topic:
    202103251505050001,appShop,2021-03-25 15:05:05,500.00,400.00,2021-03-25 15:10:00,0003,Cindy,330108
    202103241606060001,appShop,2021-03-24 16:06:06,200.00,180.00,2021-03-24 16:10:06,0001,Alice,330106
  4. Perform the following operations to view the data result in the taskmanager.out file:
    1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
    2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
    3. Go to the folder of the date, find the folder whose name contains taskmanager, download the .out file, and view result logs.
    +I[202103251505050001, appShop, 2021-03-25 15:05:05, 500.0, 400.0, 2021-03-25 15:10:00, 0003, Cindy, 330108]
    +I[202103241606060001, appShop, 2021-03-24 16:06:06, 200.0, 180.0, 2021-03-24 16:10:06, 0001, Alice, 330106]
