Help Center/
Data Lake Insight/
Flink SQL Syntax Reference/
Flink OpenSource SQL 1.15 Syntax Reference/
Constraints and Definitions/
Data Manipulation Language (DML)
Updated on 2024-04-19 GMT+08:00
Constraints and Limitations
- Flink SQL uses a lexical policy for identifier (table, attribute, function names) similar to Java:
- The case of identifiers is preserved whether they are quoted.
- Identifiers are matched case-sensitively.
- Unlike Java, back-ticks allow identifiers to contain non-alphanumeric characters (for example, SELECT a AS `my field` FROM t).
- String literals must be enclosed in single quotes (for example, SELECT'Hello World'). Duplicate a single quote for escaping (for example, SELECT 'It''s me.'). Unicode characters are supported in string literals. If explicit Unicode points are required, use the following syntax:
- Use the backslash (\) as an escaping character (default): SELECT U&'\263A'
- Use a custom escaping character: SELECT U&'#263A' UESCAPE '#'
Syntax
INSERT INTO table_name [PARTITION part_spec] query
part_spec: (part_col_name1=val1 [, part_col_name2=val2, ...])
query:
values
select
| selectWithoutFrom
| query UNION [ ALL ] query
| query EXCEPT query
| query INTERSECT query
[ ORDER BY orderItem [, orderItem ]* ]
[ LIMIT { count | ALL } ]
[ OFFSET start { ROW | ROWS } ]
[ FETCH { FIRST | NEXT } [ count ] { ROW | ROWS } ONLY]
orderItem:
expression [ ASC | DESC ]
select:
SELECT [ ALL | DISTINCT ]
{ * | projectItem [, projectItem ]* }
FROM tableExpression
[ WHERE booleanExpression ]
[ GROUP BY { groupItem [, groupItem ]* } ]
[ HAVING booleanExpression ]
[ WINDOW windowName AS windowSpec [, windowName AS windowSpec ]* ]
selectWithoutFrom:
projectItem:
expression [ [ AS ] columnAlias ]
| tableAlias . *
tableExpression:
tableReference [, tableReference ]*
| tableExpression [ NATURAL ] [ LEFT | RIGHT | FULL ] JOIN tableExpression [ joinCondition ]
joinCondition:
ON booleanExpression
| USING '(' column [, column ]* ')'
tableReference:
tablePrimary
[ matchRecognize ]
[ [ AS ] alias [ '(' columnAlias [, columnAlias ]* ')' ] ]
tablePrimary:
[ TABLE ] [ [ catalogName . ] schemaName . ] tableName
| LATERAL TABLE '(' functionName '(' expression [, expression ]* ')' ')'
| UNNEST '(' expression ')'
values:
VALUES expression [, expression ]*
groupItem:
expression
| CUBE '(' expression [, expression ]* ')'
| ROLLUP '(' expression [, expression ]* ')'
| GROUPING SETS '(' groupItem [, groupItem ]* ')'
windowRef:
windowName
| windowSpec
windowSpec:
[ windowName ]
[ PARTITION BY expression [, expression ]* ]
RANGE numericOrIntervalExpression {PRECEDING}
| ROWS numericExpression {PRECEDING}
matchRecognize:
MATCH_RECOGNIZE '('
[ MEASURES measureColumn [, measureColumn ]* ]
[ ONE ROW PER MATCH ]
[ AFTER MATCH
( SKIP TO NEXT ROW
| SKIP PAST LAST ROW
| SKIP TO FIRST variable
| SKIP TO LAST variable
| SKIP TO variable )
PATTERN '(' pattern ')'
[ WITHIN intervalLiteral ]
DEFINE variable AS condition [, variable AS condition ]*
measureColumn:
expression AS alias
pattern:
patternTerm [ '|' patternTerm ]*
patternTerm:
patternFactor [ patternFactor ]*
patternFactor:
variable [ patternQuantifier ]
patternQuantifier:
| '{' { [ minRepeat ], [ maxRepeat ] } '}' ['?']
| '{' repeat '}'
Parent topic: Constraints and Definitions
