Updated on 2025-01-10 GMT+08:00
Supported Data Types
DLI supports the following data types:
CHAR, VARCHAR, STRING, BOOLEAN, BINARY, VARBINARY, BYTES, DECIMAL, TINYINT, SMALLINT, INTEGER, BIGINT, FLOAT, DOUBLE, DATE, TIME, TIMESTAMP, TIMESTAMP_LTZ, INTERVAL, ARRAY, MULTISET, MAP, ROW, and RAW.
In the SQL syntax, these types are used to define the data types of columns within a table.
