On this page
string_split
Updated on 2023-04-27 GMT+08:00
The string_split function splits a target string into substrings based on the specified separator and returns a substring list.
string_split(target, separator)
Table 1 string_split parameters
Data Types
target
STRING
Target string to be processed
  • If target is NULL, an empty line is returned.
  • If target contains two or more consecutive separators, an empty substring is returned.
  • If target does not contain a specified separator, the original string passed to target is returned.
separator
VARCHAR
Separator. Currently, only single-character separators are supported.
Example
  1. Create a Flink OpenSource SQL job by referring to Kafka Source Table and Print Result Table, enter the following job running script, and submit the job.
    When you create a job, set Flink Version to 1.12 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs. Change the values of the parameters in bold as needed in the following script.
    CREATE TABLE kafkaSource (
      target STRING,
      separator  VARCHAR
    ) WITH (
      'connector' = 'kafka',
      'topic' = 'KafkaTopic',
      'properties.bootstrap.servers' = 'KafkaAddress1:KafkaPort,KafkaAddress2:KafkaPort',
      'properties.group.id' = 'GroupId',
      'scan.startup.mode' = 'latest-offset',
      "format" = "json"
    CREATE TABLE printSink (
      target STRING,
      item STRING
    ) WITH (
      'connector' = 'print'
    insert into printSink
      select target,
      item from
      kafkaSource,
      lateral table(string_split(target, separator)) as T(item);
  2. Connect to the Kafka cluster and send the following test data to the Kafka topic:
    {"target":"test-flink","separator":"-"}
    {"target":"flink","separator":"-"}
    {"target":"one-two-ww-three","separator":"-"}
    The data is as follows:
    Table 2 Test table data
    target (STRING)
    separator (VARCHAR)
    test-flink
    flink
    one-two-ww-three
  3. View output.
    • Method 1:
      1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
      2. Locate the row that contains the target Flink job, and choose More > FlinkUI in the Operation column.
      3. On the Flink UI, choose Task Managers, click the task name, and select Stdout to view job logs.
    • Method 2: If you select Save Job Log on the Running Parameters tab before submitting the job, perform the following operations:
      2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
      3. Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
    The query result is as follows:
    +I(test-flink,test)
    +I(test-flink,flink)
    +I(flink,flink)
    +I(one-two-ww-three,one)
    +I(one-two-ww-three,two)
    +I(one-two-ww-three,ww)
    +I(one-two-ww-three,three)
    The output data is as follows:
    Table 3 Result table data
    target (STRING)
    item (STRING)
    test-flink
    test
    test-flink
    flink
    flink
    flink
    one-two-ww-three
    one
    one-two-ww-three
    two
    one-two-ww-three
    ww
    one-two-ww-three
    three
