On this page
String Functions
Updated on 2024-09-29 GMT+08:00
Table 1 String Functions
Function
Return Type
string1 || string2
STRING
Returns the concatenation of string1 and string2.
CHAR_LENGTH(string)
CHARACTER_LENGTH(string)
INT
Returns the number of characters in the string.
UPPER(string)
STRING
Returns the string in uppercase.
LOWER(string)
STRING
Returns the string in lowercase.
POSITION(string1 IN string2)
INT
Returns the position (start from 1) of the first occurrence of string1 in string2; returns 0 if string1 cannot be found in string2.
TRIM([ BOTH | LEADING | TRAILING ] string1 FROM string2)
STRING
Returns a string that removes leading and/or trailing characters string2 from string1.
LTRIM(string)
STRING
Returns a string that removes the left whitespaces from the specified string.
For example, LTRIM(' This is a test String.') returns "This is a test String.".
RTRIM(string)
STRING
Returns a string that removes the right whitespaces from the specified string.
For example, RTRIM('This is a test String. ') returns "This is a test String.".
REPEAT(string, integer)
STRING
Returns a string that repeats the base string integer times.
For example, REPEAT('This is a test String.', 2) returns "This is a test String.This is a test String.".
REGEXP_REPLACE(string1, string2, string3)
STRING
Returns a string from string1 with all the substrings that match a regular expression string2 consecutively being replaced with string3.
For example, REGEXP_REPLACE('foobar', 'oo|ar', '') returns "fb".
REGEXP_REPLACE('ab\ab', '\\', 'e') returns "abeab".
OVERLAY(string1 PLACING string2 FROM integer1 [ FOR integer2 ])
STRING
Returns a string that replaces integer2 characters of STRING1 with STRING2 from position integer1.
The default value of integer2 is the length of string2.
For example, OVERLAY('This is an old string' PLACING ' new' FROM 10 FOR 5) returns "This is a new string".
SUBSTRING(string FROM integer1 [ FOR integer2 ])
STRING
Returns a substring of the specified string starting from position integer1 with length integer2 (to the end by default). If integer2 is not configured, the substring from integer1 to the end is returned by default.
STRING
Returns a new string which replaces all the occurrences of string2 with string3 (non-overlapping) from string1.
For example, REPLACE('hello world', 'world', 'flink') returns "hello flink"; REPLACE('ababab', 'abab', 'z') returns "zab".
REPLACE('ab\\ab', '\\', 'e') returns "abeab".
REGEXP_EXTRACT(string1, string2[, integer])
STRING
Returns a string from string1 which extracted with a specified regular expression string2 and a regex match group index integer.
Returns NULL, if the parameter is NULL or the regular expression is invalid.
For example, REGEXP_EXTRACT('foothebar', 'foo(.*?)(bar)', 2)" returns "bar".
INITCAP(string)
STRING
Returns a new form of STRING with the first character of each word converted to uppercase and the rest characters to lowercase.
CONCAT(string1, string2,...)
STRING
Returns a string that concatenates string1, string2, ….
For example, CONCAT('AA', 'BB', 'CC') returns "AABBCC".
CONCAT_WS(string1, string2, string3,...)
STRING
Returns a string that concatenates string2, string3, … with a separator string1. The separator is added between the strings to be concatenated. Returns NULL if string1 is NULL. If other arguments are NULL, this function automatically skips NULL arguments.
For example, CONCAT_WS('~', 'AA', NULL, 'BB', '', 'CC') returns "AA~BB~~CC".
LPAD(string1, integer, string2)
STRING
Returns a new string from string1 left-padded with string2 to a length of integer characters.
If any argument is NULL, NULL is returned.
If integer is negative, NULL is returned.
If the length of string1 is shorter than integer, returns string1 shortened to integer characters.
For example, LPAD(Symbol,4,Symbol) returns "Symbol hi".
LPAD('hi',1,'??') returns "h".
RPAD(string1, integer, string2)
STRING
Returns a new string from string1 right-padded with string2 to a length of integer characters.
For example, RPAD('hi',4,'??') returns "hi??".
RPAD('hi',1,'??') returns "h".
FROM_BASE64(string)
STRING
Returns the base64-decoded result from string.
Returns NULL if string is NULL.
For example, FROM_BASE64('aGVsbG8gd29ybGQ=') returns "hello world".
TO_BASE64(string)
STRING
Returns the base64-encoded result from string; f string is NULL.
For example, TO_BASE64(hello world) returns "aGVsbG8gd29ybGQ=".
ASCII(string)
INT
Returns the numeric value of the first character of string.
For example, ascii('abc') returns 97.
ascii(CAST(NULL AS VARCHAR)) returns NULL.
CHR(integer)
STRING
Returns the ASCII character having the binary equivalent to integer.
If integer is larger than 255, we will get the modulus of integer divided by 255 first, and returns CHR of the modulus.
Returns NULL if integer is NULL.
chr(97) returns a.
chr(353) Return a.
DECODE(binary, string)
STRING
Decodes the first argument into a String using the provided character set (one of 'US-ASCII', 'ISO-8859-1', 'UTF-8', 'UTF-16BE', 'UTF-16LE', 'UTF-16').
If either argument is NULL, the result will also be NULL.
ENCODE(strinh1, string2)
STRING
Encodes the string1 into a BINARY using the provided string2 character set (one of 'US-ASCII', 'ISO-8859-1', 'UTF-8', 'UTF-16BE', 'UTF-16LE', 'UTF-16').
INSTR(string1, string2)
INT
Returns the position of the first occurrence of string2 in string1.
Returns NULL if any argument is NULL.
LEFT(string, integer)
STRING
Returns the leftmost integer characters from the string.
Returns EMPTY String if integer is negative.
RIGHT(string, integer)
STRING
Returns the rightmost integer characters from the string.
LOCATE(string1, string2[, integer])
INT
Returns the position of the first occurrence of string1 in string2 after position integer.
Returns 0 if not found.
The value of integer defaults to 0.
PARSE_URL(string1, string2[, string3])
STRING
Returns the specified part from the URL.
Valid values for string2 include 'HOST', 'PATH', 'QUERY', 'REF', 'PROTOCOL', 'AUTHORITY', 'FILE', and 'USERINFO'.
If string2 is QUERY, the key in QUERY can be specified as string3.
Example:
The parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'HOST') returns 'facebook.com'.
parse_url('http://facebook.com/path1/p.php?k1=v1&k2=v2#Ref1', 'QUERY', 'k1') returns 'v1'.
REGEXP(string1, string2)
BOOLEAN
Performs a regular expression search on the specified string and returns a BOOLEAN value indicating whether the specified match pattern is found. If it is found, TRUE is returned. string1 indicates the specified string, and string2 indicates the regular expression.
REVERSE(string)
STRING
Returns the reversed string.
Note that backquotes must be added to this function, for example, `REVERSE`.
SPLIT_INDEX(string1, string2, integer1)
STRING
Splits string1 by the delimiter string2, returns the integerth (zero-based) string of the split strings. Returns NULL if integer is negative.
STR_TO_MAP(string1[, string2, string3]])
MAP
Returns a map after splitting the string1 into key/value pairs using delimiters.
The default value of string2 is ','.
The default value of string3 is '='.
SUBSTR(string[, integer1[, integer2]])
STRING
Returns a substring of string starting from position integer1 with length integer2.
If integer2 is not specified, the string is truncated to the end.
JSON_VAL(STRING json_string, STRING json_path)
STRING
Returns the value of the specified json_path from the json_string. For details about how to use the functions, see JSON_VAL Function.
The following rules are listed in descending order of priority.
  1. The two arguments json_string and json_path cannot be NULL.
  2. The value of json_string must be a valid JSON string. Otherwise, the function returns NULL.
  3. If json_string is an empty string, the function returns an empty string.
  4. If json_path is an empty string or the path does not exist, the function returns NULL.
JSON_VAL Function
  • Syntax
STRING JSON_VAL(STRING json_string, STRING json_path)
Table 2 Parameters
Data Types
json_string
STRING
JSON object to be parsed
json_path
STRING
Path expression for parsing the JSON string For the supported expressions, see Table 3.
Table 3 Expressions supported
Expression
Root node in the path
Access array elements
Array wildcard
Access child elements
  • Example
    1. Test input data.
      Test the data source kafka. The message content is as follows:
      {name:James,age:24,gender:male,grade:{math:95,science:[80,85],english:100}}
      {name:James,age:24,gender:male,grade:{math:95,science:[80,85],english:100}]
    2. Use JSON_VAL in SQL statements.
      CREATE TABLE kafkaSource (
        `message` string
      ) WITH (
        'connector' = 'kafka',
        'topic' = '<yourSourceTopic>',
        'properties.bootstrap.servers' = '<yourKafkaAddress1>:<yourKafkaPort>,<yourKafkaAddress2>:<yourKafkaPort>',
        'properties.group.id' = '<yourGroupId>',
        'scan.startup.mode' = 'latest-offset',
        "format" = "csv",
        "csv.field-delimiter" = "\u0001",
        "csv.quote-character" = "''"
      CREATE TABLE kafkaSink(
        message1 STRING,
        message2 STRING,
        message3 STRING,
        message4 STRING,
        message5 STRING,
        message6 STRING
      ) WITH (
        'topic' = '<yourSinkTopic>',
        "format" = "json"
      insert into kafkaSink select
      JSON_VAL(message,""),
      JSON_VAL(message,"$.name"),
      JSON_VAL(message,"$.grade.science"),
      JSON_VAL(message,"$.grade.science[*]"),
      JSON_VAL(message,"$.grade.science[1]"),JSON_VAL(message,"$.grade.dddd")
      from kafkaSource;
    3. Check the output result of the Kafka topic in the sink.
      {"message1":null,"message2":"swq","message3":"[80,85]","message4":"[80,85]","message5":"85","message6":null}
      {"message1":null,"message2":null,"message3":null,"message4":null,"message5":null,"message6":null}
