Raw
Updated on 2022-07-12 GMT+08:00
Function
The raw format allows you to read and write raw (byte based) values as a single column.
Note: This format encodes null values as null of the byte[] type. This may have limitation when used in upsert-kafka, because upsert-kafka treats null values as a tombstone message (DELETE on the key). Therefore, we recommend avoiding using upsert-kafka connector and the raw format as a value.format if the field can have a null value.
The raw format connector is built-in, no additional dependencies are required.
Parameters
Table 1
Mandatory
Default Value
Type
format
Yes
None
String
Format to be used. Set this parameter to raw.
raw.charset
No
UTF-8
String
Charset to encode the text string.
raw.endianness
No
big-endian
String
Endianness to encode the bytes of numeric value. Valid values are big-endian and little-endian. You can search for endianness for more details.
Supported Connectors
  • Kafka
  • UpsertKafka
Example
Use Kafka to send data and output the data to print.
  1. Create a datasource connection for the communication with the VPC and subnet where Kafka locates and bind the connection to the queue. Set a security group and inbound rule to allow access of the queue and test the connectivity of the queue using the Kafka IP address. For example, locate a general-purpose queue where the job runs and choose More > Test Address Connectivity in the Operation column. If the connection is successful, the datasource is bound to the queue. Otherwise, the binding fails.
  2. Create a Flink OpenSource SQL job and select Flink 1.12. Copy the following statement and submit the job:
    create table kafkaSource(
      log string
      ) with (
        'connector' = 'kafka',
        'topic' = '<yourTopic>',
        'properties.group.id' = '<yourGroupId>',
        'properties.bootstrap.servers' = '<yourKafkaAddress>:<yourKafkaPort>',
        'scan.startup.mode' = 'latest-offset',
        'format' = 'raw'
    create table printSink(
      log string
       ) with (
         'connector' = 'print'
    insert into printSink select * from kafkaSource;
  3. Insert the following data to the corresponding topic in Kafka:
    47.29.201.179 - - [28/Feb/2019:13:17:10 +0000] "GET /?p=1 HTTP/2.0" 200 5316 "https://domain.com/?p=1" "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36" "2.75"
  4. View the output through either of the following methods:
    • Method 1: Locate the job and click More > FlinkUI. Choose Task Managers > Stdout.
    • Method 2: If you allow DLI to save job logs in OBS, view the output in the taskmanager.out file.
    +I(47.29.201.179 - - [28/Feb/2019:13:17:10 +0000] "GET /?p=1 HTTP/2.0"2005316"https://domain.com/?p=1"
    "Mozilla/5.0 (Windows NT 6.1) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/72.0.3626.119 Safari/537.36" "2.75")
