Print Result Table
Updated on 2024-09-29 GMT+08:00
Function
The Print connector is used to print output data to the error file or TaskManager file, making it easier for you to view the result in code debugging.
None
Precautions
  • The Print result table supports the following output formats:
    Print
    Condition 1
    Condition 2
    Identifier:Task ID> Output data
    A print identifier prefix must be provided. That is, you must specify print-identifier in the WITH parameter when creating the Print result table.
    parallelism > 1
    Identifier> Output data
    parallelism == 1
    A print identifier prefix is not needed. That is, you do not specify print-identifier in the WITH parameter when creating the Print result table.
    parallelism > 1
    Output data
    parallelism == 1
  • When creating a Flink OpenSource SQL job, you need to set Flink Version to 1.12 on the Running Parameters tab of the job editing page, select Save Job Log, and set the OBS bucket for saving job logs.
Syntax
3
4
5
6
7
8
9
create table printSink (
  attr_name attr_type
  (',' attr_name attr_type) *
  (',' PRIMARY KEY (attr_name,...) NOT ENFORCED)
) with (
  'connector' = 'print',
  'print-identifier' = '',
  'standard-error' = ''
Parameters
Table 1 Parameter description
Mandatory
Default Value
Data Type
connector
Yes
None
String
Connector to be used. Set this parameter to print.
print-identifier
No
None
String
Message that identifies print and is prefixed to the output of the value.
standard-error
No
false
Boolean
The value can be only true or false. The default value is false.
  • If the value is true, data is output to the error file of the TaskManager.
  • If the value is false, data is output to the out file of the TaskManager.
Example
Create a Flink OpenSource SQL job. Run the following script to generate random data through the DataGen table and output the data to the Print result table.
When you create a job, set Flink Version to 1.12 in the Running Parameters tab. Select Save Job Log, and specify the OBS bucket for saving job logs.
create table dataGenSource(
  user_id string,
  amount int
) with (
  'connector' = 'datagen',
  'rows-per-second' = '1', --Generates a piece of data per second.
  'fields.user_id.kind' = 'random', --Specifies a random generator for the user_id field.
  'fields.user_id.length' = '3' --Limits the length of user_id to 3.
create table printSink(
  user_id string,
  amount int
) with (
insert into printSink select * from dataGenSource;
After the job is submitted, the job status changes to Running. You can perform the following operations to view the output result:
  • Method 1:
    1. Log in to the DLI console. In the navigation pane, choose Job Management > Flink Jobs.
    2. Locate the row that contains the target Flink job, click More in the Operation column, and select FlinkUI.
    3. On the Flink UI, choose Task Managers, click the task name, and select Stdout to view job logs.
  • Method 2: If you select Save Job Log on the Running Parameters tab before submitting the job, perform the following operations:
    2. Click the name of the corresponding Flink job, choose Run Log, click OBS Bucket, and locate the folder of the log you want to view according to the date.
    3. Go to the folder of the date, find the folder whose name contains taskmanager, download the taskmanager.out file, and view result logs.
