BlackHole Result Table
Function
The BlackHole connector allows for swallowing all input records. It is designed for high-performance testing and UDF output. It is not a substantive sink. The BlackHole result table is a built-in connector.
For example, if an error is reported when you register a result table of another type, but you are not sure whether it is caused by a system fault or an invalid setting of the WITH parameter for the result table, you can change the value of connector to blackhole and click Run. If no error is reported, the system is normal. You must check the settings of the WITH parameter.
None
Precautions
When creating a Flink OpenSource SQL job, you need to set Flink Version to 1.12 on the Running Parameters tab of the job editing page, select Save Job Log, and set the OBS bucket for saving job logs.
Syntax
create table blackhole_table (
attr_name attr_type (',' attr_name attr_type) *
) with (
'connector' = 'blackhole'
); Parameters
| Parameter | Mandatory | Default Value | Data Type | Description |
| connector | Yes | None | String | Connector to be used. Set this parameter to blackhole. |
Example
The DataGen source table generates data, and the BlackHole result table receives the data.
create table datagenSource ( user_id string, user_name string, user_age int ) with ( 'connector' = 'datagen', 'rows-per-second'='1' ); create table blackholeSink ( user_id string, user_name string, user_age int ) with ( 'connector' = 'blackhole' ); insert into blackholeSink select * from datagenSource;
