User-defined Result Table
Updated on 2022-07-12 GMT+08:00
Function
Write your Java code to insert the processed data into a specified database supported by your cloud service.
Implement the custom sink class :
The custom sink class is inherited from Flink open-source class RichSinkFunction. The data type is Tuple2<Boolean, Row>.
For example, define the MySink class by public class MySink extends RichSinkFunction< Tuple2<Boolean, Row>>{}, and implement the open, invoke, and close functions. A code example is as follows:
public class MySink extends RichSinkFunction<Tuple2<Boolean, Row>> {
    // Initialize the object.
    @Override
    public void open(Configuration parameters) throws Exception {}
    @Override
    // Implement the data processing logic.
    /* The in parameter contains two values. The first value is of the Boolean type. The value true indicates the insert or update operation, and the value false indicates the delete operation. If the interconnected sink does not support the delete operation, the deletion will not be executed. The second value indicates the data to be operated.*/
    public void invoke(Tuple2<Boolean, Row> in, Context context) throws Exception {}
    @Override
    public void close() throws Exception {}
Content of the dependent pom configuration file is as follows:
<dependency>
    <groupId>org.apache.flink</groupId>
    <artifactId>flink-streaming-java_2.11</artifactId>
    <version>${flink.version}</version>
    <scope>provided</scope>
</dependency>
<dependency>
    <artifactId>flink-core</artifactId>
</dependency>
Pack the implemented class and compile it in a JAR file, and upload it using the UDF Jar parameter on the editing page of your Flink OpenSource SQL job.
Syntax
create table userDefinedSink (
  attr_name attr_type
  (',' attr_name attr_type)*
with (
  'connector.type' = 'user-defined',
  'connector.class-name' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. The value can only be a user-defined sink.
Yes
Fully qualified class name of the sink class. For details about the implementation of the sink class, see Prerequisites.
connector.class-parameter
No
Parameter of the constructor of the sink class. Only one parameter of the string type is supported.
Precautions
connector.class-name must be a fully qualified class name.
Example
  attr1 int,
  attr2 int
with (
  'connector.class-name' = 'xx.xx.MySink'
