ClickHouse Result Table
Updated on 2024-11-08 GMT+08:00
Function
DLI exports Flink job data to ClickHouse result tables.
ClickHouse is a column-based database oriented to online analysis and processing. It supports SQL query and provides good query performance. The aggregation analysis and query performance based on large and wide tables is excellent, which is one order of magnitude faster than other analytical databases. For details, see Using ClickHouse from Scratch.
You have established an enhanced datasource connection to ClickHouse and set the port in the security group rule of the ClickHouse cluster as needed.
For details about how to set up an enhanced datasource connection. For details, see "Enhanced Datasource Connection" in the Data Lake Insight User Guide.
For details about how to configure security group rules, see Security Group Overview in the Virtual Private Cloud User Guide.
Precautions
  • When you create a ClickHouse cluster for MRS, set the cluster version to MRS 3.1.0 and do not enable Kerberos authentication.
  • Do not define a primary key in Flink SQL statements. Do not use any syntax that generates primary keys, such as insert into clickhouseSink select id, cout(*) from sourceName group by id.
  • Flink supports the following data types: string, tinyint, smallint, int, long, float, double, date, timestamp, decimal, and Array.
    The array supports only the int, bigint, string, float, and double data types.
Syntax
3
4
5
6
7
8
9
create table clickhouseSink (
  attr_name attr_type
  (',' attr_name attr_type)*
with (
  'connector.type' = 'clickhouse',
  'connector.url' = '',
  'connector.table' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Result table type. Set this parameter to clickhouse.
connector.url
Yes
ClickHouse URL.
Parameter format: jdbc:clickhouse://ClickHouseBalancer instance IP address:HTTP port number for ClickHouseBalancer instances/Database name
  • IP address of a ClickHouseBalancer instance:
    Log in to the MRS management console, click a cluster name, and choose Components > ClickHouse > Instance to obtain the service IP address of the ClickHouseBalancer instance.
  • HTTP port of a ClickHouseBalancer instance:
    Log in to the MRS management console, click the target cluster name. On the displayed page, choose Components > ClickHouse. In the Service Configuration tab, choose ClickHouseBalancer from the All Roles dropdown list and search for lb_http_port to configure the parameter. The default value is 21425.
  • The database name is the name of the database created for the ClickHouse cluster.
connector.table
Yes
Name of the ClickHouse table to be created
connector.driver
No
Driver required for connecting to the database
  • If this parameter is not specified during table creation, the driver automatically extracts the value from the ClickHouse URL.
  • If this parameter is specified during table creation, the value must be ru.yandex.clickhouse.ClickHouseDriver.
connector.username
No
Account for connecting the ClickHouse database
connector.password
No
Password for accessing the ClickHouse database
connector.write.flush.max-rows
No
Maximum number of rows to be updated when data is written. The default value is 5000.
connector.write.flush.interval
No
Interval for data update. The unit can be ms, milli, millisecond/s, sec, second/min or minute.
connector.write.max-retries
No
Maximum number of attempts to write data if failed. The default value is 3.
Example
Read data from a DIS table and insert the data into the test table of ClickHouse database flinktest.
  1. Create a DIS source table disSource.
     3
     4
     5
     6
     7
     8
     9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    create table disSource(
      attr0 string,
      attr1 TINYINT,
      attr2 smallint,
      attr3 int,
      attr4 bigint,
      attr5 float,
      attr6 double,
      attr7 String,
      attr8 string,
      attr9 timestamp(3),
      attr10 timestamp(3),
      attr11 date,
      attr12 decimal(38, 18),
      attr13 decimal(38, 18)
    ) with (
      "connector.type" = "dis",
      "connector.region" = "cn-xxxx-x",
      "connector.channel" = "xxxx",
      "format.type" = 'csv'
  2. Create ClickHouse result table clickhouse and insert the data from the disSource table to the result table.
    create table clickhouse(
      attr0 string,
      attr1 TINYINT,
      attr2 smallint,
      attr3 int,
      attr4 bigint,
      attr5 float,
      attr6 double,
      attr7 String,
      attr8 string,
      attr9 timestamp(3),
      attr11 date,
      attr13 decimal(38, 18),
      attr14 array < int >,
      attr15 array < bigint >,
      attr16 array < float >,
      attr17 array < double >,
      attr18 array < varchar >,
      attr19 array < String >
    ) with (
      'connector.url' = 'jdbc:clickhouse://xx.xx.xx.xx:xx/flinktest',
      'connector.table' = 'test'
    insert into
      clickhouse
    select
      attr0,
      attr1,
      attr2,
      attr3,
      attr4,
      attr5,
      attr6,
      attr7,
      attr8,
      attr9,
      attr10,
      attr11,
      attr12,
      attr13,
      array [attr3, attr3+1],
      array [cast(attr4 as bigint), cast(attr4+1 as bigint)],
      array [cast(attr12 as float), cast(attr12+1 as float)],
      array [cast(attr13 as double), cast(attr13+1 as double)],
      array ['TEST1', 'TEST2'],
      array [attr7, attr7]
    from
      disSource;
