Type Conversion Function
Syntax
CAST(value AS type)
Syntax Description
This function is used to forcibly convert types.
Precautions
If the input is NULL, NULL is returned.
Example
The following example converts the amount value to an integer.
insert into temp select cast(amount as INT) from source_stream;
| Example | Description | Example |
| cast(v1 as string) | Converts v1 to a string. The value of v1 can be of the numeric type or of the timestamp, date, or time type. | Table T1: | content (INT) | | ------------- | | 5 | Statement: SELECT cast(content as varchar) FROM T1; Result: "5" |
| cast (v1 as int) | Converts v1 to the int type. The value of v1 can be a number or a character. | Table T1: | content (STRING) | | ------------- | | "5" | Statement: SELECT cast(content as int) FROM T1; Result: 5 |
| cast(v1 as timestamp) | Converts v1 to the timestamp type. The value of v1 can be of the string, date, or time type. | Table T1: | content (STRING) | | ------------- | | "2018-01-01 00:00:01" | Statement: SELECT cast(content as timestamp) FROM T1; Result: 1514736001000 |
| cast(v1 as date) | Converts v1 to the date type. The value of v1 can be of the string or timestamp type. | Table T1: | content (TIMESTAMP) | | ------------- | | 1514736001000 | Statement: SELECT cast(content as date) FROM T1; Result: "2018-01-01" |
Flink jobs do not support the conversion of bigint to timestamp using CAST. You can convert it using to_timestamp.
Detailed Sample Code
/** source **/ CREATE TABLE car_infos (cast_int_to_string int, cast_String_to_int string, case_string_to_timestamp string, case_timestamp_to_date timestamp(3)) WITH ( 'connector.type' = 'dis', 'connector.region' = 'xxxxx', 'connector.channel' = 'dis-input', 'format.type' = 'json' ); /** sink **/ CREATE TABLE cars_infos_out (cast_int_to_string string, cast_String_to_int int, case_string_to_timestamp timestamp(3), case_timestamp_to_date date) WITH ( 'connector.type' = 'dis', 'connector.region' = 'xxxxx', 'connector.channel' = 'dis-output', 'format.type' = 'json' ); /** Statistics on static car information**/ INSERT INTO cars_infos_out SELECT cast(cast_int_to_string as string), cast(cast_String_to_int as int), cast(case_string_to_timestamp as timestamp), cast(case_timestamp_to_date as date) FROM car_infos;
