Window
Updated on 2024-09-29 GMT+08:00
GROUP WINDOW
Group Window is defined in GROUP BY. One record is generated from each group. Group Window involves the following functions:
  • Array functions
    CAUTION:
    • For SQL queries in stream processing tables, the time_attr parameter of the grouping window function must reference a valid time attribute, which needs to specify the processing time or event time of the row.
    • For batch SQL queries, the time_attr parameter of the grouping window function must be a TIMESTAMP type attribute.
    Table 1 Array functions
    Grouping Window Function
    TUMBLE(time_attr, interval)
    Defines a tumbling time window. A tumbling time window assigns rows to non-overlapping, continuous windows with a fixed duration (interval). For example, a tumbling window of 5 minutes groups rows in 5 minutes intervals. Tumbling windows can be defined on event-time (stream + batch) or processing-time (stream).
    HOP(time_attr, interval, interval)
    Defines a hopping time window (called sliding window in the Table API). A hopping time window has a fixed duration (second interval parameter) and hops by a specified hop interval (first interval parameter). If the hop interval is smaller than the window size, hopping windows are overlapping. Thus, rows can be assigned to multiple windows. For example, a hopping window of 15 minutes size and 5 minute hop interval assigns each row to 3 different windows of 15 minute size, which are evaluated in an interval of 5 minutes. Hopping windows can be defined on event-time (stream + batch) or processing-time (stream).
    SESSION(time_attr, interval)
    Defines a session time window. Session time windows do not have a fixed duration but their bounds are defined by a time interval of inactivity, i.e., a session window is closed if no event appears for a defined gap period. For example a session window with a 30 minute gap starts when a row is observed after 30 minutes inactivity (otherwise the row would be added to an existing window) and is closed if no row is added within 30 minutes. Session windows can work on event-time (stream + batch) or processing-time (stream).
  • Window auxiliary functions
    You can use the following helper functions to select the start and end timestamps, as well as the time attribute, for grouping windows.
    CAUTION:
    When calling helper functions, it is important to use the same parameters as those used in the GROUP BY clause for grouping window functions.
    Table 2 Window auxiliary functions
    Auxiliary Function
    TUMBLE_START(time_attr, interval)
    HOP_START(time_attr, interval, interval)
    SESSION_START(time_attr, interval)
    Returns the timestamp of the inclusive lower bound of the corresponding tumbling, hopping, or session window.
    TUMBLE_END(time_attr, interval)
    HOP_END(time_attr, interval, interval)
    SESSION_END(time_attr, interval)
    Returns the timestamp of the exclusive upper bound of the corresponding tumbling, hopping, or session window.
    Note: The exclusive upper bound timestamp cannot be used as a rowtime attribute in subsequent time-based operations, such as interval joins and group window or over window aggregations.
    TUMBLE_ROWTIME(time_attr, interval)
    HOP_ROWTIME(time_attr, interval, interval)
    SESSION_ROWTIME(time_attr, interval)
    Returns the timestamp of the inclusive upper bound of the corresponding tumbling, hopping, or session window. The resulting attribute is a rowtime attribute that can be used in subsequent time-based operations such as interval joins and group window or over window aggregations.
    TUMBLE_PROCTIME(time_attr, interval)
    HOP_PROCTIME(time_attr, interval, interval)
    SESSION_PROCTIME(time_attr, interval)
    Returns a proctime attribute that can be used in subsequent time-based operations such as interval joins and group window or over window aggregations.
Example
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
// Calculate the SUM every day (event time).
insert into temp SELECT name,
    TUMBLE_START(ts, INTERVAL '1' DAY) as wStart,
    SUM(amount)
    FROM Orders
    GROUP BY TUMBLE(ts, INTERVAL '1' DAY), name;
//Calculate the SUM every day (processing time).
    SUM(amount)
    FROM Orders
    GROUP BY TUMBLE(proctime, INTERVAL '1' DAY), name;
//Calculate the SUM over the recent 24 hours every hour (event time).
insert into temp SELECT product,
    SUM(amount)
    FROM Orders
    GROUP BY HOP(ts, INTERVAL '1' HOUR, INTERVAL '1' DAY), product;
//Calculate the SUM of each session and an inactive interval every 12 hours (event time).
    SESSION_START(ts, INTERVAL '12' HOUR) AS sStart,
    SESSION_END(ts, INTERVAL '12' HOUR) AS sEnd,
    SUM(amount)
    FROM Orders
    GROUP BY SESSION(ts, INTERVAL '12' HOUR), name;
TUMBLE WINDOW Extension
Function
The extension functions of the DLI tumbling window are as follows:
  • Periodical tumbling windows for lower latency
    Before the tumbling window ends, the window can be periodically triggered based on the configured frequency. The compute result from the start to the current time is output, which does not affect the final output. The latest result can be viewed in each period before the window ends.
  • Custom latency for higher data accuracy
    You can set a latency for the end of the window. The output of the window is updated according to the configured latency each time a piece of late data reaches.
Precautions
If you use insert to write results into the sink, the sink must support the upsert mode.
Syntax
TUMBLE(time_attr, window_interval, period_interval, lateness_interval)
Example
If the current time_attr attribute column is testtime and the window interval is 10 seconds, the statement is as follows:
TUMBLE(testtime, INTERVAL '10' SECOND, INTERVAL '10' SECOND, INTERVAL '10' SECOND)
Table 3 Parameter description
Format
time_attr
Event time or processing time attribute column
window_interval
Duration of the window
  • Format 1: INTERVAL '10' SECOND
    The window interval is 10 seconds. You can change the value as needed.
  • Format 2: INTERVAL '10' MINUTE
    The window interval is 10 minutes. You can change the value as needed.
  • Format 3: INTERVAL '10' DAY
    The window interval is 10 days. You can change the value as needed.
period_interval
Frequency of periodic triggering within the window range. That is, before the window ends, the output result is updated at an interval specified by period_interval from the time when the window starts. If this parameter is not set, the periodic triggering policy is not used by default.
lateness_interval
Time to postpone the end of the window. The system continues to collect the data that reaches the window within lateness_interval after the window ends. The output is updated for each data that reaches the window within lateness_interval.
If the time window is for processing time, lateness_interval does not take effect.
Values of period_interval and lateness_interval cannot be negative numbers.
  • If period_interval is set to 0, periodic triggering is disabled for the window.
  • If lateness_interval is set to 0, the latency after the window ends is disabled.
  • If neither of the two parameters is set, both periodic triggering and latency are disabled and only the regular tumbling window functions are available .
  • If only the latency function needs to be used, set period_interval INTERVAL '0' SECOND.
OVER WINDOW
The difference between Over Window and Group Window is that one record is generated from one row in Over Window.
Syntax
 3
 4
 5
 6
 7
 8
 9
10
11
SELECT agg1(attr1) OVER (
  [PARTITION BY partition_name]
  ORDER BY proctime|rowtime
  ROWS
 BETWEEN (UNBOUNDED|rowCOUNT) PRECEDING AND CURRENT ROW FROM TABLENAME
  RANGE
  BETWEEN (UNBOUNDED|timeInterval) PRECEDING AND CURRENT ROW FROM TABLENAME
Table 4 Parameter description
Parameter Description
PARTITION BY
Indicates the primary key of the specified group. Each group separately performs calculation.
ORDER BY
Indicates the processing time or event time as the timestamp for data.
ROWS
Indicates the count window.
RANGE
Indicates the time window.
Precautions
  • All aggregates must be defined in the same window, that is, in the same partition, sort, and range.
  • Currently, only windows from PRECEDING (unbounded or bounded) to CURRENT ROW are supported. The range described by FOLLOWING is not supported.
  • ORDER BY must be specified for a single time attribute.
Example
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
// Calculate the count and total number from syntax rules enabled to now (in proctime).
    count(amount) OVER (PARTITION BY name ORDER BY proctime RANGE UNBOUNDED preceding) as cnt1,
    sum(amount) OVER (PARTITION BY name ORDER BY proctime RANGE UNBOUNDED preceding) as cnt2
    FROM Orders;
//Calculate the count and total number of the recent four records (in proctime).
    count(amount) OVER (PARTITION BY name ORDER BY proctime ROWS BETWEEN 4 PRECEDING AND CURRENT ROW) as cnt1,
    sum(amount) OVER (PARTITION BY name ORDER BY proctime ROWS BETWEEN 4 PRECEDING AND CURRENT ROW) as cnt2
    FROM Orders;
//Calculate the count and total number last 60s (in eventtime). Process the events based on event time, which is the timeattr field in Orders.
    count(amount) OVER (PARTITION BY name ORDER BY timeattr RANGE BETWEEN INTERVAL '60' SECOND PRECEDING AND CURRENT ROW) as cnt1,
    sum(amount) OVER (PARTITION BY name ORDER BY timeattr RANGE BETWEEN INTERVAL '60' SECOND PRECEDING AND CURRENT ROW) as cnt2
    FROM Orders;
