HBase Dimension Table
Updated on 2023-04-27 GMT+08:00
Function
Create a Hbase dimension table to connect to the source stream.
  • An enhanced datasource connection has been created for DLI to connect to HBase, so that jobs can run on the dedicated queue of DLI and you can set the security group rules as required.
  • If MRS HBase is used, IP addresses of all hosts in the MRS cluster have been added to host information of the enhanced datasource connection.
    For details, see Modifying the Host Information in the Data Lake Insight User Guide.
Syntax
create table hbaseSource (
  attr_name attr_type
  (',' attr_name attr_type)*
with (
  'connector.type' = 'hbase',
  'connector.version' = '1.4.3',
  'connector.table-name' = '',
  'connector.zookeeper.quorum' = ''
Parameters
Table 1 Parameter description
Mandatory
connector.type
Yes
Connector type. Set this parameter to hbase.
connector.version
Yes
The value must be 1.4.3.
connector. table-name
Yes
Table name in HBase
Yes
ZooKeeper address
connector.zookeeper.znode.parent
No
Root directory for ZooKeeper. The default value is /hbase.
Example
create table hbaseSource(
  id string,
  i Row<score string>
 ) with (
   'connector.table-name' = 'user',
   'connector.zookeeper.quorum' = 'xxxx:2181'
create table source1(
  id string,
  name string,
  geneder string,
  age int,
  address string,
  proctime as PROCTIME()
) with (
  "connector.type" = "dis",
  "connector.region" = "ap-southeast-1",
  "connector.channel" = "read",
  "connector.ak" = "xxxxxx",
  "connector.sk" = "xxxxxx",
  "format.type" = 'csv'
 create table hbaseSink(
  rowkey string,
  i Row<name string, geneder string, age int, address string>,
  j ROW<score string>
 ) with (
   'connector.table-name' = 'score',
   'connector.write.buffer-flush.max-rows' = '1',
 insert into hbaseSink select d.id, ROW(name, geneder,age,address), ROW(score) from source1 as d join hbaseSource for system_time as of d.proctime as h on d.id = h.id;
