GaussDB(DWS) Dimension Table
Create a GaussDB(DWS) dimension table to connect to the input stream.
- You have created a GaussDB(DWS) instance for your account.
Syntax
1 2 3 4 5 6 7 8 9 10 11 |
create table dwsSource ( attr_name attr_type (',' attr_name attr_type)* ) with ( 'connector.type' = 'gaussdb', 'connector.url' = '', 'connector.table' = '', 'connector.username' = '', 'connector.password' = '' ); |
Parameters
Parameter |
Mandatory |
Description |
connector.type |
Yes |
Connector type. Set this parameter to gaussdb. |
connector.url |
Yes |
JDBC connection address. The format is jdbc:postgresql://${ip}:${port}/${dbName}. |
connector.table |
Yes |
Name of the table where the data to be read from the database is located |
connector.driver |
No |
JDBC connection driver. The default value is org.postgresql.Driver. |
connector.username |
No |
Database authentication user name. This parameter must be configured in pair with connector.password. |
connector.password |
No |
Database authentication password. This parameter must be configured in pair with connector.username. |
connector.read.partition.column |
No |
Name of the column used to partition the input This parameter is mandatory if connector.read.partition.lower-bound, connector.read.partition.upper-bound, and connector.read.partition.num are configured. |
connector.read.partition.lower-bound |
No |
Lower bound of values to be fetched for the first partition This parameter is mandatory if connector.read.partition.column, connector.read.partition.upper-bound, and connector.read.partition.num are configured. |
connector.read.partition.upper-bound |
No |
Upper bound of values to be fetched for the last partition This parameter is mandatory if connector.read.partition.column, connector.read.partition.lower-bound, and connector.read.partition.num are configured. |
connector.read.partition.num |
No |
Number of partitions This parameter is mandatory if connector.read.partition.column, connector.read.partition.upper-bound, and connector.read.partition.upper-bound are configured. |
connector.read.fetch-size |
No |
Number of rows fetched from the database each time. The default value is 0, indicating the hint is ignored. |
connector.lookup.cache.max-rows |
No |
Maximum number of cached rows in a dimension table. When the rows exceed this value, the data that is added first will be marked as expired. The value -1 indicates that data cache disabled. |
connector.lookup.cache.ttl |
No |
Time To Live (TTL) of dimension table cache. Caches exceeding the TTL will be deleted. The format is {length value}{time unit label}, for example, 123ms, 321s. The supported time units include d, h, min, s, and ms (default unit). |
connector.lookup.max-retries |
No |
Maximum number of attempts to obtain data from the dimension table. The default value is 3. |
Example
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 |
CREATE TABLE car_infos ( car_id STRING, car_owner STRING, car_brand STRING, car_price INT, proctime as PROCTIME() ) WITH ( 'connector.type' = 'dis', 'connector.region' = 'ap-southeast-1', 'connector.channel' = 'disInput', 'format.type' = 'csv' ); CREATE TABLE db_info ( car_id STRING, car_owner STRING, car_brand STRING, car_price INT ) WITH ( 'connector.type' = 'gaussdb', 'connector.driver' = 'org.postgresql.Driver', 'connector.url' = 'jdbc:gaussdb://xx.xx.xx.xx:8000/xx', 'connector.table' = 'car_info', 'connector.username' = 'xx', 'connector.password' = 'xx', 'connector.lookup.cache.max-rows' = '10000', 'connector.lookup.cache.ttl' = '24h' ); CREATE TABLE audi_cheaper_than_30w ( car_id STRING, car_owner STRING, car_brand STRING, car_price INT ) WITH ( 'connector.type' = 'dis', 'connector.region' = 'ap-southeast-1', 'connector.channel' = 'disOutput', 'connector.partition-key' = 'car_id,car_owner', 'format.type' = 'csv' ); INSERT INTO audi_cheaper_than_30w SELECT a.car_id, b.car_owner, b.car_brand, b.car_price FROM car_infos as a join db_info FOR SYSTEM_TIME AS OF a.proctime AS b on a.car_id = b.car_id; |
