Elasticsearch Result Table
Function
DLI exports Flink job output data to Elasticsearch of Cloud Search Service (CSS). Elasticsearch is a popular enterprise-class Lucene-powered search server and provides the distributed multi-user capabilities. It delivers multiple functions, including full-text retrieval, structured search, analytics, aggregation, and highlighting. With Elasticsearch, you can achieve stable, reliable, real-time search. Elasticsearch applies to diversified scenarios, such as log analysis and site search.
CSS is a fully managed, distributed search service. It is fully compatible with open-source Elasticsearch and provides DLI with structured and unstructured data search, statistics, and report capabilities. For more information about CSS, see Cloud Search Service User Guide.
- Ensure that you have created a cluster on CSS using your account.
If you need to access Elasticsearch using the cluster username and password, enable the security mode and disable HTTPS for the created CSS cluster.
- In this scenario, jobs must run on the dedicated queue of DLI. Therefore, DLI must interconnect with the enhanced datasource connection that has been connected with CSS. You can also set the security group rules as required.
- You have set up an enhanced datasource connection. For details, see Enhanced Datasource Connections in the Data Lake Insight User Guide.
- For details about how to configure security group rules, see Security Group Overview in the Virtual Private Cloud User Guide.
Precautions
- Currently, only CSS 7.X and later versions are supported. Version 7.6.2 is recommended.
- Do not enable the security mode for the CSS cluster if connector.username and connector.password are not configured.
- ICMP must be enabled for the security group inbound rule of the CSS cluster.
Syntax
create table esSink (
attr_name attr_type
(',' attr_name attr_type)*
(','PRIMARY KEY (attr_name, ...) NOT ENFORCED)
with (
'connector.type' = 'elasticsearch',
'connector.version' = '7',
'connector.hosts' = 'http://xxxx:9200',
'connector.index' = '',
'connector.document-type' = '',
'update-mode' = '',
'format.type' = 'json'
Parameters
Parameter |
Mandatory |
Description |
connector.type |
Yes |
Connector type. Set this parameter to elasticsearch. |
connector.version |
Yes |
Elasticsearch version Currently, only version 7 can be used. That is, the value of this parameter can only be 7. |
connector.hosts |
Yes |
Host name of the cluster where Elasticsearch locates. Use semicolons (;) to separate multiple host names. Ensure that the host name starts with http, for example, http://x.x.x.x:9200. |
connector.index |
Yes |
Elasticsearch index name |
connector.document-type |
Yes |
Elasticsearch type name This attribute is invalid because Elasticsearch 7 uses the default _doc type. |
update-mode |
Yes |
Data update mode of the sink. The value can be append or upsert. |
connector.key-delimiter |
No |
Delimiter of compound primary keys. The default value is _. |
connector.key-null-literal |
No |
Character used to replace null in keys. |
connector.failure-handler |
No |
Policy used when an Elasticsearch request fails. The default value is fail. fail: An exception is thrown when the request fails and the job fails. ignore: The failed request is ignored. retry-rejected: If the request fails because the queue running the Elasticsearch node is full, the request is resent and no failure is reported. custom: A custom policy is used. |
connector.failure-handler-class |
No |
Custom processing mode used to handle a failure |
connector.flush-on-checkpoint |
No |
Whether the connector waits for all pending action requests to be acknowledged by Elasticsearch on checkpoints. The default value true indicates that wait for all pending action requests on checkpoints. If you set this parameter to false, the connector will not wait for the requests. |
connector.bulk-flush.max-actions |
No |
Maximum number of records that can be written in a batch |
connector.bulk-flush.max-size |
No |
Maximum total amount of data to be written in batches. Specify the unit when you configure this parameter. The unit is MB. |
connector.bulk-flush.interval |
No |
Update interval for batch writing. The unit is milliseconds and is not required. |
format.type |
Yes |
Data format. Currently, only JSON is supported. |
connector.username |
No |
Account of the cluster where Elasticsearch locates. This parameter and must be configured in pair with connector.password. If the account and password are used, the security mode must be enabled and HTTPS must be disabled for the created CSS cluster. |
connector.password |
No |
Password of the cluster where Elasticsearch locates. This parameter must be configured in pair with connector.username. |
Example
create table sink1( attr1 string, attr2 int ) with ( 'connector.type' = 'elasticsearch', 'connector.version' = '7', 'connector.hosts' = 'http://xxxx:9200', 'connector.index' = 'es', 'connector.document-type' = 'one', 'update-mode' = 'append', 'format.type' = 'json' );
